Do the flip kit
Thanks, I just gotta get out of my own head. Let the build begin
Yea I got a single piece shaft ,but I took yalls advice and ordered the two piece.
I have a question regarding the front drops. I started with mcgaughys 3" struts ?... garbage. Then I switched to the djm 4" upper and lower control arms ??.. They are awesome , but now I want 2 more inches in the front... My gut says spindles but is anybody running the 2" drop strut springs in the front ? If so how's the ride....
Your problem was running struts at the lowest point. And djm is absolute garbage. You'll find out after having it on for awhile.  But yes if you want lower. Get spindles
Maybe so on the struts ,but I've put 30k on those djm arms. Truck rides smooth, stays in alignment, and I have no premature inner tire ware. I paid $150 for those mcgaughy struts straight from them... falls back to you get what you pay for. I don't just drive around my town in my ride. It goes on 7 hour drives to south Texas twice a month usually. Truck has 90k on it and has been 4/9 for over half of that.
On 1/31/2018 at 2:49 PM, blownZ71 said:
I am in a similar position as you were. I have the rear leveled with the shackles but want to go lower. Is your front suspension steel or aluminum? As I have not really been able to find any solutions for an aluminum front A-arm setup on a 4x4. How did the alignment go on the front? Also, any rubbing of your 285's, or even close? My 305's barely rub at full lock so just wondering how bad that might get.
Mine is Aluminum, currently I am lowered 2" in the front with Belltech struts, rides great, no alignment issues, the only time i get a bit of a rub is in reverse at full lock, and its just rubbing on my mud flaps so not too concerned i should really find some new ones since these sit an inch off the ground now that its lowered haha.
If you are looking to drop 2" or less the struts are a great option imo, I kind of want to go a little lower now I have been considering some DJM 2" control arms and going back up a little with the shocks for around 3-3.5" total in the front and then I would drop the back from 5 to 6. Decisions..
That would be the worst thing you can do.  Using a strut and 2" arm.  That will make your front wheel closer to the rear of the front wheel well. Which looks ugly and more rubbing.  If you want 2 more inches you do spindles
I lowered the rear of my 15 Sierra with bell tech 2” drop shackles. I also purchased the lowering brackets for the rear shocks but they didn’t come with my installation instruction. Could someone explain to me what the third 3/8 bolts is for. Am I supposed to drill a hole and bolt it to stock bracket?
Looks to me like you got an extra...
http://www.belltech.com/extras/docs/BBGC/6651.pdf
13 minutes ago, Bonjosco3ss said:
You.drill a hole in the stock mount. So the extended doesn't pivot   that's what the small bolt if for
Exactly what I was looking for. Thank you.
After lowering the rear of my truck with belltech shackles and block removal, i have decided i want to lower the front 1". Has anyone successfully used belltech lowering strut part #25004 on 2018 stamped LCAs? Belltech only shows that the drop spindles are compatible.
TIA
TIA
I have them on my 2017 with the stamped LCAs and they work just fine.
    B07
    B07
  • Who's Online   2 Members, 1 Anonymous, 833 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
