Yes and is it a rc or cc?
Mine is a rc. Truck is fighting me a bit today, getting the caltracs installed, but I'll get those pics for you as soon as I can put the weight of the truck on the axle
Are you at a 4/6? I havent seen your truck
7 hours ago, Nasty said:
Can you get me a quick picture.  I need to see the distance between your frame and axle pad in the rear. If you can hold a tape .measure in there that would be even better
Is this what you need? Sorry, it's sideways DSC_0811.thumb.JPG.80a16c7288b8f4fbb937d2f21fc41413.JPG
He posted it on the previous page :lol:
I was at 4/5, but once I get the truck back on the ground, I'll be at 4/6.f5768463c11f6a95f587946c13f213e3.jpg
That's at 5.  I'd you can do the same at 6 that would be perfect. Becsuse I might lift mine from 7to 6 in the rear
Thank you! My truck is a 4x4 so I had to do it a little different than most guys with 2wd trucks. I have 2" spindles with stock shocks and 2" lowering springs up front, and a flip kit in the rear set at 5 in that pic but next week I'll be bringing the rear to 6".
I had to do the same thing on my ‘16 CC Lovelessjl due to having 4WD... I currently sit at 4/7 based on my measurements from the ground... I used MaxTrac everything with the same setup you did...d80c762a4754682c3310a296a0454787.jpeg
Are you doing to notch it? I'm at 4/7 in my rc and I almost need a notch.  Cc sit lower than rc
No issues with my setup so I’m not gonna notch it... My flip kit is set at 5” but I had my blocks removed so I’m between 6”-7” in the rear...
Here is frame to pad, without a bump stop with the flip kit set at 6"a2bdfb7f65e882cdd4e3448c65f7462e.jpg
I’ll have mine on a lift on Thursday so I’ll measure mine as well...
1 more measurement while you're at it  center of hub to the fender. In the rear please.    I think I'm lifting mine to 6
this makes me want to got to 6'' since it's only 1/2'' difference in height.
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
