On 12/16/2022 at 9:16 AM, Lowerdz964 said:
At 7.25 how close is your axle to your frame rails?
Not really sure how close to the frame. It looks like it has plenty of room. I haven't bottomed out any, but I have not really driven it too much since I am still working on some modifications in the garage on it.
Also, sorry for the late response. For some reason, I am not getting notified when someone comments on this site.
Belltech 2 inch drop Spindles, Belltech 1-3" adjustable struts set to 1" drop for 3" total drop
Belltech 5-6 flip kit set to 5" (stock block removed) for 5" total Drop
Belltach Drop shocks rear
IHC helper bags for lowered trucks set to 20 LBS
Truck is Level rides smooth.
Edited by Jerry Flaherty
  • 5 months later...
I went through the 226 pages looking for the torque specs on the shackle bolts. Putting drop shackles on my ‘18 Sierra this weekend and haven’t been able to find the spec. If I missed it, my apologies. Anyone have them?
On 10/15/2020 at 6:01 PM, Melks said:
2/5
What drop size and kit did you go with for that? It's perfect.
  • 5 months later...
Just checking in about something I was going to do years ago, but only got around to doing today.
I have a 2016 Silverado WT, 4X4, ECLB.
A few years back i installed the McGauthy's spindles in the front, and 2" shackles in the back.
Today I knocked out the rear blocks between the springs and the axel, and replaced the bolts with the shorter style.
So total drop now I guess is 2 / 3.25.
I stuck my head under the truck, and it may be sitting on the OEM bump stops, or maybe just touching them, not sure. I know a few years back I had a load of topsoil in the box and driving home it felt solid. I assume it was well down on the bump stops at that time.
I Jump up and down on the tailgate (I'm about 250 pounds) and it seems fine, not solid, like the day with the topsoil and it seems the shocks were working good. After the blocks were removed (and new 22" tires) the mechanic said it seems to ride better now overall (I picked him up this morning and he drove it back, then picked me up this afternoon).
In the driveway on a small grade it currently measures 35-3/8" from the center of the wheel well in the fender to the ground, Front and rear.
Here's my question...
I am planning on towing my 02 Monte Carlo on a (U-Haul aluminum) flat deck 1/2 way across Canada later this summer. Should I do anything about the bump stops? Has anyone maybe taken a hack saw and cut one of the hoops off the end of an OEM bump stop maybe?
Also I was told by U-Haul the sweet spot for the distance to the top of the ball plate should be 18 - 20". The top of my receiver is currently 16". So at a minimum I am going to have to flip some type of hitch to get me in that range.
Any / all comments about my current setup and what to expect on a 3,000+ mile driver later this summer, are welcomed. Curious if the current setup is fine, or if I should address anything.
Thanx,
Krunch
Edited by krunch
I cut my factory bump stops on my truck like 5 years ago when I did the same rear drop on my crew cab. I've towed trailers with it countless times, no issues at all. Sure it rides the bump stop still with a heavy load in the back but I don't care at all.
  • 5 months later...
How many of you have transmission spacers installed with your lowering kit? I initally lowered my truck with the IHC 3"/5" kit (I have since put back in stock LCA's and put in drop spindle - I kept the flip kit) and it did not include a spacer. If you can get the pinion angles addressed without it do you still need it?
On 10/31/2013 at 3:38 PM, mjw930 said:
I'm looking for the best way to lower the rear of my 2014 2WD 1500 about 1.5". That will still give it about a 1.5" rake which should mean level when I'm towing. I considered drop shackles but was reading about removing the rear lift plate that's between the axle and spring.
My question is can the leaf spring sit directly on the axle or is some sort of spacer / bushing required for proper alignment and isolation?
Golden Panda Casino propose une gamme de méthodes de paiement qui ont une exigence de dépôt minimum. En ce qui concerne les dépôts, le montant minimum que vous pouvez déposer n'est que de 10 €ou l'équivalent dans d'autres devises. Nous utilisons une technologie de cryptage puissante pour protéger tous nos paiements https://goldenpandacasino.fr/ garantissant que vos données personnelles et financières sont totalement sûres et sécurisées. Nous proposons également une variété de méthodes de retrait pratiques sans frais supplémentaires. Nous traitons toujours nos retraits dès que possible et, dans la plupart des situations, ils sont effectués en 48 heures ou moins. Si vous avez des préoccupations concernant nos méthodes de paiement ou comment effectuer un dépôt ou un retrait, n'hésitez pas à nous contacter à tout moment. Nous sommes présents 24 heures sur 24, 7 jours sur 7, pour nous assurer que toutes vos transactions sur Golden Panda Casino se déroulent le mieux possible!
If you do the shackles and blocks you will be dropping more than the 2" the shackles provide. I did nothing to the bump stops.
On 11/8/2022 at 9:00 PM, Graham1992 said:
2016 silverado RCSB 4/6 drop with 22X10 MRR T228's.
Wow. I’m speechless on that truck. IMG_1828.thumb.jpeg.4f966d54cb433462356c65a7dc3d9ed8.jpeg
On 9/2/2022 at 6:30 PM, Chuchito said:
I just finished installing an adjustable 3/4, 4/6, 5/7 kit on my 2018 regular cab Sierra. I first installed it to be 4/6 but was not happy with the look. Looked to high in the back. I then installed the factory hanger back and it gave me an additional 1-1/4” drop. Now it looks like the front sits a bit higher in the front. Front is Maxtrac 2” spindles with Belltech struts set at 2” drop for a total of 4”. So apparently I am now at a a 4/7.25.
I am trying to figure out how to get the front just a little lower without running into rubbing issues.
Truck looks awesome. How do you like the ride with the front struts?
Heys guys new to the group, sorry for the long post, I recently bought an 18’ Sierra 1500. Came with a belltech lowering kit on it which I believe is/was a 3/5 street performance kit. When I got the truck, everything was loose like the previous owner was afraid to overtighten things lol. As a professional mechanic I went over the truck myself and tightened everything new tires and alignment. While doing so found the front struts were blown. Talked to a friend who recommended the maxtrac adjustable struts. Installed them on the lowest setting and only got about 1-2 months before they were blown. I want to order complete new front coils and struts but don’t know which will be best route. I was told the belltech kit uses stock coils but is that true? Should I buy new oem strut/coil assemblies and swap the strut? Here is truck currently on 22” Denali wheels and tires
I have Belltech 25004 struts on my 2018. They do use the stock coils. They ride better than the factory Ranchos and have lasted 40k miles. Nice truck!
Thanks! I think going to buy complete new coil strut assemblies and just swap out the struts. I think whoever installed the lowering kit before I got the truck forgot parts or installed wrong. Or I’m now looking into the belltech coilovers.
    TopBo
    TopBo
  • Who's Online   3 Members, 0 Anonymous, 1,537 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
