3 hours ago, NoLand said:
I’m using this kit.
how do you like it?
26 minutes ago, qwank said:
What didn't you like about it?
I liked them.  Just don'tneed them anymore
how do you like it?
It’s fine. I liked the fact that I didn’t have to make any modifications that couldn’t be reversed, so the bolt on aspect appealed to me. But the instructions were lacking and having lived with it for awhile, I don’t care for the design. There is a bar that goes between the axle and the leaf springs where the bag mounts. It causes some squeaking as the suspension cycles (and the bar runs the leaf spring pack). Also, since I wasn’t a full 6” drop, I also had to purchase a 2” spacer to work (since I’ve got the flip kit with the lift shackles for a ~ 5” drop).
The kit works, as I pull a 6000# travel trailer with my lowered truck. But I think the Air Lift design would be a little better. Not enough to take it off and switch, but if I had it to do over again...
I put some rubber in between.
Alright guys I need some help deciding between Belltech or Mcgaughys. Parts numbers are 989sp for Belltech and 34270 for Mcgaughys. Which one and why?
Sent from my SAMSUNG-SM-N920A using Tapatalk
I dont like either for a regular cab.   What drop are you going?
What would you recommend? I'm not sure if I want 3/6 4/6 4/7 that's why I was leaning towards a adjustable kit. I have stamped steel control arms.
Id go 4/6.  I have some shocks for you if you want. Only reason i took them off was becsuse igot a good deal on some qa1 adjustables
What kit do you recommend? I see some kits come with shocks, should I buy those or a kit without shocks and buy different shocks? This is a lot harder than I expected lol
Id buy a kit without shocks and get your own.   Its easy.  You are just making it hard
Good afternoon all, new to the forum. Just bought a 17 sierra double cab with the belltech 4/7. I have searched for this issue but have yet to find an answer on it. les schwabs is the company who lowered it prior to me purchasing the truck.  They only did 6" in the rear. So (added the 1" shackle I believe) anyways. They say if I go the full 7" I will sag in the rear. Yet when I measured,  it measures 1" taller in the rear than the front. So sat I'm taking it back to have them take the 1" shackle out (or at least that what I think they have to do) but has anyone else noticed a sag in the rear with the full 4/7 apposed to the 4/6? Thank you in advance. I have not seen a single picture with the 4/7 that looks like its sagging. Thank you for your help. Sorry if this has been covered.
Double cab and crecrew cab need a notch tbey sit lower.
Although I appreciate your help. I did not ask about the notch. I am simply wondering if the 4/7 sits level or safe in the rear.   As for the notch. I have seen many that do not notch w the 4/7.  But its tight.
It will sit level but it wont appear level.  The rear fender on k2 trucks sits lower.   A 4/6 on dc and cc should appear level
Thank you kindly for your reply and knowledge
    • Bro, you still got that truck? I'm not seeing any m rust or flaking, which rusted metal flakes. Everyone thinks the wax "is rusty" but it absorbs its surrounding environment, creating a hard, natural shell that you can literally shoot with a bullet and won't flake off. It'll last 50 years like that as long as the barrier isn't compromised by getting in a wreck or meets a chemical that disolves wax. My 09's frame is even duller looking than that, and is holding up better than my rockers or 3rd set of painted shocks.
    • No.   That would be an LT and higher trim.  Passive entry.  There would be a little button on the door handle and you can program it to proximity lock or unlock.     WT and Custom do not get this feature.
    • Mediocre, how much did they lose on the poorly conceived EV strategy?   I wonder how much the stock price is being 'inflated' by all the buy-backs?   Cadillac literally looks like a brand without a rudder, no clear goals or product direction - performance or luxury? I guess performance because we can throw a small block in whatever we can and call it a day. Certainly not luxury when a Denali or High Country is reasonably cross shoppable. The Celestiq - no way - no vehicle can command quarter million prices when something wearing the same badge is on the buy here pay here lot across town.   Notice the 'base' Escalade doesn't even come with the 'leather-appointed' seating surfaces.   Hummer EV - fail Silverado EV - fail Sierra EV - fail Bolt/Volt EV (The most successful EV cancelled, restarted, cancelled, whatever its current status it)   Hybrids - none Sedans - none Medium duty - not anymore Minivan - none Coupe - none Convertible - none CUVs - 20+/-   6.2 Recall that landed squarely on the GMs highest seller - and specifically the fattest margin higher trims of the Yukon, Escalade, et. al. The most critical product line they fumbled big time. In the Escalade segment, are those buyers forgiving GM for a bad engine and patiently waiting for the fixes and dealing with the headaches? Nope, they dump them and go straight to the other premium brands.   In the ENTIRE GM portfolio how many aspirational vehicles are there? Corvette, Escalade (quickly being superseded by the obvious better value Denali)...   I posted somewhere else... what if Cadillac left the luxury game and became a performance brand similar to AMG or (gasp) Ferrari? Cut all the entry-level and base models from their line up and focus on the V-series or Blackwing or whatever they call it now. Of course, those would have the pre-requisite luxury and technology as standard equipment. This opens the floor for Buick to step in/up as the luxury brand (like they are in China), no 'performance pretenses' get rid of the 'entry-level' models with equally 'entry-level' power trains and become the Maybach to Cadillacs AMG. With those two brands effectively out of the way Chevrolet, the 'entry-level' brand has the floor to itself and GMC can take over as 'professional grade'.    Now each brand has a focus, no in-fighting, clear direction, and customer targets.   Just need to sneakily slide Corvette into the Cadillac brand and dump the vestigial script writing.
    • I can't get enthusiastic about the 1.5T (or the 1.3 or the 1.2), I won't drive a CVT. But the stupid things sell in volume.
    • There is a big difference in motorcycles and vehicles - nobody needs a motorcycle, they WANT one. That WANT is the most powerful force to drive price upwards.   I've hated every iteration of the Equinox, a prime example of GM laziness. It excelled at absolutely nothing, barely competitive by every metric. At least the latest generation looks decent.    I want to like the Buick Envista, but that pitiful engine plus FWD only is a BIG NO for me, I don't care how good it looks.
