How i would do it is put 2 rings in front bringing it up to 3" drop.  And then drop the ass end 1 more inch making it a 3/5 drop but thats just me
Copy that! Man I really appreciate the help and quick replies! You don’t see that much these days. Thank you!
Ive messed with my suspension so many times i can do it in my sleep.  Im currently at a 4.5/7   soon to be 5/8.
I went from 3/6 to what i am now. You wont like 2/4.  Just go straight to a 3/5. And your stock tires willstill be fine
I have the same truck and color!
Nasty, what is not good about the 2/4?
Not that I was thinking of that combo...I wanted to go as you mentioned 3/5, but didn't want to flip the axle and make cuts.
So, I'm on the fence and thinking of just removing the rear blocks and 2" shackle, but I would think my ass would be too low and front at stock height?
Also, does lowering the truck help diminish roll during turns or is there a stiffer sway bar and springs that need to be changed out?
I don't mind a stiff suspension as long as it does what it's supposed to do and there's no hacking/welding on the frame.
2/4 on these trucks doesnt even look like its been lowered.  The only cut you make is the bump stop mounts.  Which is nothing
My truck actually rides better then it did stock
If I cut the bump stops, will that mean I can't go back to stock later?
Cut them off straight like i did. So they can be welded back on   i qont have to worry aboyt that because im getting a notch
3 hours ago, Nasty said:
4 hours ago, Breedsrt said:
That looks great!!!
Yeah, you dropped it 4'' in the front with the springs and shocks.   I wish mine looked that low in the front with my 4'' drop.
Edited by qwank
Looking at 2 different kits...2/4 & 3/5 from 2 different manufacturers.
I know there's a lot of people using the BellTech 2/4, but does anyone have experience with MaxTrac 3/5.
Belltech lowers the front with struts, where MaxTrac lowers the front with spindles and springs.
My thought is with Belltech the use of struts only and keeping the OEM spindles may have less chances of bad handling characteristics/fit issues, should the spindles be slightly off one way or another.
However, I'm not sure if this has happened or how good their kits are quality wise..hence any experience with MaxTrac spindles and springs?
Another question, how much carrying capacity is lost when the rear is lowered without using bags?
Always use spindles if you can
Can you elaborate on why you feel this way, and have you used MaxTrac before or know of anyone that has?
1 minute ago, qwank said:
Belltech has spindles also
Are you using these on your truck?
If so, do you know the kit number?
Yes, I am using these on my truck. You have a 2016 so the part numbers are different depending on which control arm style you have. I used part number 2514 which fits stamped steel and aluminum control arms.
When you lower 07-18 silverados with struts pr spring. The lower you go, the farther back the front wheel goes back into the wheel well. Which causes mkre rubbing and looks horrible.   Spindles wont affect that
Yes, I just checked the sight, and I have cast control arms. My truck is an early 2016, and the kits say aluminum.
I'll reach out the to sales person I talked to earlier to see if they have spindles for cast CA...Thanks!
    tararebecca
    tararebecca
  • Who's Online   1 Member, 0 Anonymous, 513 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
