Ok, with as cheap as this is and simple I am interested in it now.
With as cheap and simple as this is......GM should have made this standard. It's 2014 for crying out loud! Other Truck manufacturers are doing this. Why couldn't GM do it when they introduced this truck a year ago?
Finally got this done today. Very simple job and this write up made the wiring into the interior wire bundle very easy.
Thanks MotoMedic
Did mine the other day. Thanks MotoMedic, great write up, appreciate your time writing it up!
Is there a YouTube video for this?
The install? Probably not. You should be fine with just the posted instructions.. it's not a difficult install.
Thanks MotoMedic made install painless. Took less than an hour from start to finish.
thanks! im getting this! what do you connect the wires in the cab with ? scotchlocks?
Edited by 155
Up to you. Kit comes with taps/connectors but I prefer to splice in and used heat-shrinked connections.
I just tried to install mine...everything was fine until the wiring part I found the brown with yellows, I have 2, one smaller guage hten the others, then I found a couple solid greys all the same thickness...wtf anybody have anything different here..?
^ I believe one of the Grey wire is thicker than the other.. look at Moto's pic again to see the different..
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
