installed mine last night. it was pretty easy for me as I used to install caraudio back in the day.
but I just ran my wire along the factory wire loom on the drivers side, then up into the cab through the same grommet as the parking brake cable. I was able to feed a screwdriver through the same hole with the wire taped to it. I was able to cut off about 3 feet of excess wire and run it right up into the loom by the drivers door under the carpet. did not have to cut or drill anything!
works like a champ!
Thanks OP! I just ordered and will install this weekend. This is a must!
25mins start to finish including a hand washing and a cold beer! Works perfect. Thanks for detailed install - made this a cake install
For those who have installed the power tailgate lock, does your tailgate drop harshly at the bottom? Mine start off slow then a harsh drop at the end
In case this can help someone I'll post some pics from my install. The wires are the thicker ones if there are some the same color. I used my girl's sewing pins to poke into the wire and test before making my final install. I then pull back the insulation and wrap the wires onto the factory wire. Then solder them up before wrapping them with silicone tape and zip ties to make sure it never comes loose.
AMP Steps
Amp steps 1
Amp steps 2
Well, I am jealous of you guys that got 'er done in under an hour...
Tried to install today and failed...round 1 - failed install.
Got the tailgate stuff done and started to run the long wiring harness to the front of the truck. As I connected the short and long harnesses together, one of the wires came out of the connector on the short harness. Spent time trying to get the pin out of the connector to fix it and gave up. Placed a call to Pop N Lock, we agreed quickly not to try any more to fix it and now a new short harness is on the way. Good customer service. Stay tuned for round 2...
Chuck I may need your assistance on this on since it's next on my to do list and it looks like we are in the same city.
Sure. I didn't get very far though. I'll let you know when I get it finished. Kinda disappointed that the darned wire cam out of the connector!?!
Pop N Lock customer service sent me the new short harness and all is working great now...round 2 - COMPLETE WIN
Thanks to Moto's instructions and all the rest of you guys who posted pics of the wires!
Edited by chuckl1218
Found on Amazon for $79. All other placed I have found this kit are aroung $105-115. Anyone find a better price?
Pop N Lock won't honor warranty for kits sold at retailers like Amazon. From the Pop N Lock website...
Please note that Pop & Lock™ Products purchased on auction sites such as Ebay, Amazon and Craig's List, etc. will not be covered under factory warranty under any circumstances. Pop & Lock™ LLC (and Pop & Lock™ Corporation) is unable to verify whether products sold through auction sites are new, used, or refurbished, therefore, Pop & Lock LLC (and Pop & Lock™ Corporation) is unable to warranty such purchases. Pop & Lock LLC advises using extreme caution when purchasing our locks through auction sites as you'll be doing so at your own risk.
If you aren't concerned with the warranty issue then I think that is about the lowest price I have seen.
Yeah something to consider. Amazon is $79 and free 2 day shipping (I'm a Prime member) while direct from Pop and Lock will cost me $115 ($99 + $15 shipping). It's only a 1 year warranty so may be worth the small risk to save 1/3 the Pop and Lock price....
Edited by Nickshu
Installed mine today, works great! Took me about an hour to install, but I'm slow and very detail-oriented. Cut out, spliced and shrink wrapped the excess cable, carefully routed things, it was helpful to drop the spare tire to get access to route and secure the cable here (Plus I got to try the spare tire mechanism for this first time, good practice if I ever get a flat). I did use the supplied alligator jumper connectors, but they are pretty bulky and tough to fit the hinged cover back on with them in place. I like the post above with it soldered, I may go back and do it this way later.
Edited by Nickshu
This same thing was brought up about the Bak Flip F1 cover. I contacted them and they said it was a mistake and it was intended for items not sold from a retailer. They said if I purchased it from Amazon and have a receipt for it that they would honor the warranty. If you buy it from some guy that is not a retailer then you will not get a warranty. This is likely the same thing here. If you do buy from Amazon and not some guy selling on Amazon you will likely be fine. Of course, you would have to contact them to confirm. It would be pretty silly for them to not recognize the worlds largest online retailer as a valid seller. I got mine from there and at $80 I couldn't care less if they honor it really.
Edited by Crf450r420
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
