22 hours ago, SILVER SLED said:
It's only louder on harder acc.  And its more a consistent sound.  The 5.3 would make noise then suddenly get quiet while steadily accelerating.   On the 6.2 it's loud while accelerating briskly the entire time your in it.
Thanks Silver Sled
For those that live in California how are you buying the Airaid MIT tube? I've tried Auto anything and Airaid website and neither will ship to California.
Sent from my SAMSUNG-SM-N920A using Tapatalk
I’m happy with the s&b intake, carven exhaust, and diablo sport tune. Truck is a lot more responsive
I'm in the process of trying to solve CAI noise on these trucks.  With my Volant and its POS design, the first ingredient was isolating the airbox from the fenderwell metal.  After installing a foam lining, vibration went down pretty significantly.  My theory is most of the other noise comes from the reverberation of noise from the hollow fenderwell area itself.  I think it really amplifies it throughout the cab.  If I ever get some effing time off soon, I'm going to stuff  it with blankets.  If that makes even an inkling of difference, I'm going to line it with sound deadening material.  We'll see.
Im sure this has been covered. But does anyone have proof that any gains seen, don't disappear soon as the ecm learns...
Just seen that SLP has a cai available, on the 6.2 states gaines of 11.3 RWHP @ 3850 rpm and 15.5 RWTQ @ 3800 rpm. Sounds good, also stats does not need ecm recalibrated and doesn't void factory warranty. For what it's worth.
On 9/22/2017 at 5:30 PM, 2017SierraSLT said:
I went with the Volant CAI on my '17 Sierra. The install was straightforward. All parts were of high quality, and fit and finish were well above average. The performance gains were pretty noticeable. I followed the instructions and disconnected the battery, to erase the PCM memory. The sound is nice. I am going to purchase the latest Diablosport tuner to work with my '17.
Are you still happy with this buy, just checking in
Yes. Works as advertised.
I installed the gm CAI on my 2014, just purchased a replacement filter 23231630 from the dealer. 100 bucks and some change, took a week for the dealer to get it. I noticed on the box it was shipped for K&N engineering in CA. I have looked on the K&N website and could not find an exact match.
So does anyone known what the part number would be, in the hopes of saving some cash in the future.
Did the K&N cold air intake. I’m a big fan of this system and my mileage has never been better.
I will say, Under about 1200rpm - 1800 or so, it gives off a bit of a lower burble or Metallica sound. Once it gets above 1800rpm or so. It sucks air like a beast and sounds great.
Anyone else have this?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
