Yup that's it.On the back(facing the back seat)there is a single 12volt lighter plug no adio or hvac controls that some of the high end trucks have
still a little confused on the parts I need. 1911-a1 if I order the 5 part numbers you listed, will that give me the complete console to install or do I need more parts to complete a full
black console thx for the numbers
Edited by silveradosid
As far as I know yes it should be everything needed with the exception of the work necessary to make the wiring work for your truck.
The other members here that have made the swap would know better than I would but that should be everything.I'm still looking into the micro usb cable to connect to the HMI.
Can anyone tell me how long this cable will need to be? All the one's I've found so far are 12" long for jumping two cell phones together but i'm thinking these won't be long enough.
Don't know the exact length but it has to be more than 12'. Goes from hmi module behind glove box down to the console outlets.
are the parts numbers differnt in the usa the main console number 23466999 doesn't exit in Canada sorry for double post
I'm guessing you meant longer than 12" not 12'? :)
Can't answer that one.The parts dept. at your dealer might be able to cross reference it and get you a #.
The #23466999 is the current part for the 14-15 chevy in stock at General Motors in Lansing Mi as of yesterday according to my dealer.Dealer price was a little steep for me though. Good Luck
Thank you,I appreciate the help
Ron
As far as the mini usb cable, I have seen tbarn and other members say that they have used this, http://www.amazon.com/ACDelco-19303328-Original-Equipment-Cable/dp/B00S0ERKIS, as the cable connected to the hmi, but the connectors need to be trimmed to fit. Although at this point, I am still unclear of the purpose of the mini usb cable that plugs into the hmi. Maybe someone can explain it.
Yea, my bad.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 291 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
