does 2018 fit 2016 silverado?
Physically, yes.
Does anyone have the parts list for the cocoa interior? Interested in this as well
This is a parts list for the dark Ash interior in my 2017 z71 lt. I think the website I used is a little bit more expensive so I’ll have to shop around, just wanted to get a quote from a different place.
On 3/16/2018 at 1:23 PM, b-garage said:
I still emailed gmpartsnow back asking for some sort of confirmation that the console part # does come with the lid and back cover, but nothing back just yet.
So what is the updated parts list ?  I'm doing a swap for my buddy but you said some parts aren't needed?
The question was whether 84288040 actually comes with the updated  wireless charging armrest lid and the back cover. GMPartsnow says it does.
This is the quote I received from GMPartsnow that I posted on the previous page of this thread. This is what I ordered last week. Suppose to be here Monday 3/26. I will let everyone know what shows up after I receive it.
Regards,
big rog (b-garage)
Jim from GMPartsnow responded with a quote:
Order Content
Part Number
Make
Part Name
List
Price
Quantity
Total
84193710
GM
Harness
$35.87
$23.93
$23.93
84288040
GM
Console
$571.33
$387.36
$387.36
22776807
GM
Console Assembly Front Bracket
$22.10
$16.58
$16.58
23467516
GM
Side Trim
$35.73
$25.08
$25.08
22817347
GM
Side Trim
$77.43
$52.50
$52.50
84092080
GM
Upper Trim Panel
$214.28
$145.28
$145.28
11609982
GM
Fender Liner Bolt
$4.57
$3.26
2
$6.52
Subtotal Amount:
$657.25
Edited by b-garage
Alright guys so I've done tons of digging and I apologize. But all I am seeing is people discussing for the newer year silverado's. I have a 2014. How exactly do you go about getting the exact part list to do the center console swap?
Find a truck with the exact color console and options(such as wireless charging) and get the Vin number. Call or email a gm parts supplier( I used GmPartsNow) and give them that Vin and tell them you need a complete list of everything needed. They should email you with a list and a link.
FYI I used gm parts now and used promo code “quote10” at checkout and got 10 percent off my order. It’s. It a whole lot, but it payed for shipping and then some.
Awesome thank you. Looks like I will have to go looking at some trucks at dealerships to find the console and same trim that I have. Thanks!
I used auto trader and found one online while at work(don’t tell my boss)  saved me a bunch of time and a trip to the dealer.
I actually just did the same. I found a 2017 same trim which is reverse tartan. Only difference is it has leather seats and mine is cloth. Now this may be a dumb question. Does it matter if it is a 2017 or do I need to specifically find a 2014?
I don’t think it matters. It’s actually better because you get wireless charging. But I would maybe check out the first few pages and re read that. Or maybe @pgamboa can chime in. He’s gotta build you a custom wiring harness anyways so he may know better.
Any console from 2014 to 2018 will fit your truck.
I have a 2018 Rally 2 and I'd like to install the console. While looking at similar trucks for part numbers I noticed that some of the trucks have 4 port covers for the 110v, USB, etc. and others only have 3 covers. How do I tell which setup would be compatible with my truck?
I just did the same and requested a quote.  I'll post it here once I get it back.  (secretly hoping the price has gone down)
Edited by BluEyeItln
On 3/19/2018 at 9:38 AM, b-garage said:
I finally got an email confirmation from Jim at GMPartsnow that the console assembly 84288040 does come with the arm rest lid and back cover.  So I ordered everything today.  Will let you know if they were right when it gets here for sure.
Here is what came with my order...
IMG_3862.JPGAlso rec'd the side plates, bolts, bracket and cables, just not in the pics.
Edited by b-garage
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
