I got a present today. Just waiting on the harness from Phil (PGamboa) then I’ll complete this and receive my dual usb plug in for the trim piece to arrive. Till then, front bracket is installed and usb has been run through glovebox for now...1336050f8c1ab27bdc749f5e3ce7c2f4.jpg540391a49644bd7136661d81a67e9f00.jpge8095951afb92c9f8dc55d9c8b7f3dd5.jpg1829dab6d61db04d2de58c372c9c7ec9.jpg
Looks good! You'll love it, easily the best mod I've done to the truck
Hey thanks. Yea I know I’m going to be happier with this mod. Probably will be my best one too.
I have to agree with you both.   I just did a road trip and was able to charge all my devices, plug in my laptop and still had at least four power plugs available.  For the lighter plugs I put in two usb adapters.  I dont smoke so, more plugs!!!!
That gives me 6 usb and one ac plug up front.
Console swap complete and fully functional!! Thanks to Phil (PGamboa) and his harness. Looks so much better than the jump seat!!ddd85ce9be1e5e35135e2dcb581ef56e.jpg287d487618d61002e2bcf5bbc2c7b3e4.jpg
Dumb question... Is there any difference between double and crew cab consoles? I wouldn't think there would be, but I wanted to make sure, because in researching the swap, I've seen a few things that make me wonder.
Nope , Just did a swap in a W/T single cab , Looks awesome , with floor shifter for 4 wheel
where did you order this from? trying to buy one now...
Gmpartsnow.com
So I have a 2017 1500 Custom with no 110 plug, also is it possible to have the wireless charging unit? Ive been reading alot of this thread but there is little info on the Custom/WT model lol I really want to swap!
You can gain wireless charging as long as the new center console has it. My harness will have the circuits for it. You’ll need to see the first post and let me know if your jump seat harness has a 16-Pin connector on the end or a 23-Pin. It plugs up under the passenger seat.
You won’t have a way to drive the 110VAC on the new console.
I got my wireless charger working (old module before 2018 ). Charges my iPhone X really well. Didn’t turn the pad around either.
Removed the magnet?
