Hey Phil,
The 84288042 is backordered all over with no ETA. Is the only difference between the 8042 and 8045 the chrome handle? Do you know if the 8045 will fit a Silverado?
Thanks,
Jim
Yes it will.
Hi there,
I'm brand new to this forum....although I have been reading through this topic tirelessly trying to figure out everything I need to upgrade my truck. I apologize in advance for any duplicate questions, but I was hoping for any/all advice in regards to part numbers. I have a 2018 Silverado LT double cab Z71. My interior is black with the carbon fiber trim. The info I have gathered is that I'll need:
84288040 - Console Assembly: w/o Denali, w/o rear DVD, black
84092079 - Upper Trim Panel: w/110-volt outlet, synthesis (reverse tartan - carbon fiber)
23467516 - Side Trim: Left w/o e-assist, black
22817347 - Side Trim: Right w/o e-assist, black
22776807 - Front Mounting Bracket
84022323 - Cable: Black to Brown
19119050 - Cable: Black to Grey
84022315 - Cable: Green to Grey
11609982 - Bolts (2)
Phil's Harness
Would one or more of you fellas help me confirm this info based on your experience? Does the console assembly come with the lid? Any and all help is greatly appreciated!!
Best - Greg
Hi there,
Phil's Harness
Best - Greg
Greg, PM me. I may have a solution for you to lessen the headache :)
Quick question.   Will an iPhone 8 Plus fit on the mat that is in these consoles?  Specifically looking at the 84288040 console....  I tried to put my iPhone on my dad's 2016 LTZ console and the phone did not lay down on the mat...  I do not have a case on the phone either....
iPhone XR in a Spec case will not lay flat but charges fine with the Qi charger installed in the console lid. Charging indicator in the display indicates charge as does the phone.
XR is 3.2" wide in the Spec case. iPhone 8 plus is 3.07" wide without a case according to Apple.
pgamboa any news on the vendor you are working with yet?
Edited by larryhyman
 Sounds like you'll have a number for the complete console soon, I'm interested.
On 1/3/2019 at 8:17 PM, GregH2018 said:
Hi there,
Phil's Harness
Best - Greg
I am right there with you.  I have the exact truck that I just purchased and couldn't find one I liked with the bucket seats.  Ultimately I chose exterior color over the center console.
I have watched Phil's Youtube video on this at least three times and now just need to find the correct console.
Nope. Phone is too wide. Any plus models or the XS Max will not fit. But it will charge with the 2018 charging module/lid. I have the XS Max with the Apple leather case and it charges.
Yes. I can order these now from a supplier. Current prices are:
$750 - Console
$75 - USB Cables
$150 - Harness
$975 total - shipped anywhere in the US.
Due to a small handful of damaged consoles, the price will be increasing a little but will include insurance.
Hi there,
Phil's Harness
Best - Greg
I don’t know what 84288040 will get ya... but everything else looks right.
I can get these now from a supplier complete. With the wireless charging lid.
What color console comes in the trucks with the Cocoa / Dune interior?  Would a black one look strange?  Or are they all black?
These are the parts for a cocoa interior. The main console piece(most expensive one) is on back order till god knows when. Good luck
Got my console and associated parts today. Now just waiting on Phil’s harness. 005a05b38a1cbe4720f1e282a37186e3.jpg
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,121 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
