While those bulbs will technically work in the backup blubs spot they aren't really bright enough for you to be able to see anything with. You might not even be able to tell they are on over the light your brake lights put out.
Agreed. I went back to the regular bulbs cause they put off more light than the leds I had in there. A good led bulb costs too much for what it's worth
EDIT: This was on my 02
Sent while in 'Murica...
Edited by rdnckhntr94
Never mind. I bought the 10 pairs. I can use them for backup bulbs and license plate bulbs. And give a couple pairs to my father in law.
Yea just like Coaster said, those things are not going to help at all in the reverse lights. Those are going hurt your vision more than anything.
Added the Z71 logo on my bed today. I like the sticker and the badging up front too.
Looks good! I have thought about it for over a year. I have even seen them on other color trucks, mostly the black/gray stickers. I really like the way yours looks with the red "Z". I put the All Terrain grille in mine and added the Z71 grille badge. Thanks for posting.
Thanks! Yeah I love your grill! I planned on doing the same thing just gotta get the money for it haha. I saw that full lock has the stickers on his slt and thought man that's cool.
I've had my 14 denali for about 4 months and I've done a few things; window tint including windshield and sunroof, HID 6000k kit, LED fog lights to match color of headlights, billet 9" antenna, 24" KMC wheels, 3" drop on rear, gatorhyde spray in bed liner, rolling bed cover, more to come soon! Loving the truck so far
Anyone looked into or have rollpan installed? 3rd brake light changed out? Removed front emblem? I tried to look thru previous post but so many didn't see it anywhere
Edited by FORGIVEN06
Tinted windows with nano film
Changed stock 4x4 z71 emblem.
Bedrug with bullring tie downs.
Cooper st maxx 275-65-20
2" level
1.5" zone body lift
Plastidipped bow ties.
post-130620-141857222532_thumb.jpgpost-130620-14185722341_thumb.jpgpost-130620-141857225458_thumb.jpg
factory paint matched egr fender flares.
  • Like 4
Has anyone removed rear emblems on GMC yet?
Yes, I did when I bought the truck last November. It really easy, took me about 15 min. You need a heat gun, fishing line, and a rubber wheel on a drill.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,290 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
