How are you liking the Katzkin covers? How much were they? Worth it? They look great though
I don't like cloth seats so the katzkin's where a great up grade plus theyre made extremely well. For about $500 I'd say their definitely worth it ?? I highly recommend them if you're in the market for leather seat covers
Got jumped off. For some reason it decided the battery was low and wouldn't start... only been setting for about 20 min from the last drive...
I don't like cloth seats so the katzkin's where a great up grade plus theyre made extremely well. For about $500 I'd say their definitely worth it I highly recommend them if you're in the market for leather seat covers
Did you install seat heaters? If so, what fuse locations did you use? I have a regular cab, and both left and right "heated seat" fuses are in the drivers side panel. Strange decision.
Well battery is bad...great truck is only 14 months old and I bet its not covered under warranty......
I just did the covers no seat heaters
Installed ranch quick lifts. Front now sits at 39" and rear 39.5"
33" tires on stock 18" wheels
Installed a pair of black Anzo LED tail lights (Anzo part 311238) to replace factory kit.
Pretty simple install - i used this video and it worked well:
Keep in mind that the reverse lights and side marker lights are still analog bulbs so if you want to make it match you will need to buy a pair of 194's for the side marker lights and 921's for the reverse lights (FYI i tried with analog and it looked cheesy!). When installing the replacement reverse and marker lights, the connections are directional. Before remounting the lenses check the bulbs to see if they are on. If not just remove from their socket and rotate.
Total installation time (at my snail pace) was 30 minutes.
Edited by caveat71
Changed my cabin air filter, looks like the prior owner/dealer thought it was optional
Would think at the minimum it would be pro rated or pending dealer, covered.
Diped the headlight trim to see if I liked it in black.
This made me change my mind on the 6inch black running boards and go with the 4" tubular assist step...........
GM sport bar with aftermarket lights and GM fender flares
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
