Those will work.
Sweet thank you for the help
Sent from my SAMSUNG-SM-N910A using Tapatalk
Braved the heat today and cleaned her up! Washed, clay barred, and waxed! New tires going on tomorrow! d6fb1f3a670239b5ccfac0e8ce8c7a9d.jpg
how often do u clay?
Every time I wash my truck. Which is about every 2-3 months.
Clay barring is like sanding your paint. Do it too often and you will ruin your paint. Professional detailer will tell you (if he's not trying to sell you a detail job) the only time you need to claybar is if you have alot of tar, sap, or other build up on your paint. It was actually invented to remove paint overspray....
Edited by Cooldaddygroove
^^^lol!! Claying is NOT like sanding your paint. It removes contaminates bonded to the paint. It doesn't remove clear coat, like wet sanding or buffing would do. It does not hurt anything. Just do a google search. I've been doing it for years. Claying twice a year is recommended.
Edited by cbrsilv15
yes and no. if you are claying way too often not using a detailing spray while doing it, as well and not working the clay and using fresh clay as you go along you can absolutly marr the crap out of your paint. As you say it pulls you contaminants and if all you are doing is dragging these around that is bad.
like anything it takes some practice to do well and most people would be best off to buy a junk door panel from a yard and take it from a 20 year old dull crappy paint to having it shine and smooth before touching a $50,000 truck if it like your first new car ever. maybe others have had many and done more auto stuff growing up like me or you but most have not.
Edited by Alpine Truck Life
Detailing is way too much work... lol... but I agree claying is just a non intrusive cleaning process. Clean clay is key though... don't just reuse tge contaminated crap over and damage tge paint... then you are sanding. It does work well and I have done it myself... nowdays I will just pay someone to do it lol. I had an entire car covered in overspray and clay ed it back to decency again.
Sent from my SM-G900W8 using Tapatalk
Edited by 1994Vmax
I would have to disagree and say that clay baring requires zero practice. It's stupid easy. Either one of two things happen. First, you're using enough liquid and it glides like butter. Or your not using enough liquid and it sticks like mud unlike you lube and get the clay back together.
^^lol. Using toilet paper is easy, yet some people screw that up with disastrous results. It's harmless and super easy to do. Watch a YouTube video first and you'll be a pro.
I think that type of video may be better suited for a fetish search on PornHub.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
