Yesterday afternoon, my son and I replaced the front brake pads. Wil post pictures after I get home from work tonight.
In the picture below, you will see why I had to change them.  When I got my oil changed, they informed me that one of the pads was less than 2mm, that was 2 weeks ago.  The top one is the outboard pad, and the other one is the inboard pad.  Pads on the other side had a little more pad left then the right outboard pad, and they are evenly worn.  Went ahead and replaced all four.  Keeping the left ones, as a spare set.
Edited by Ravenkeeper
Added promised pictures.
I'd like to see those!
Sent from my SAMSUNG-SM-G935A using Tapatalk
These are even easier than peeling plasti dip or emblems off. These are just decals that lay over the oem ones, come in several colors and stay on very well. Has been through several car washes, winter, etc. Very cheap, easy, and durable!853b6a12589601cfc80ec902dcbf7346.jpg19231dba752272dccec916495ff518a0.jpg
Link please :)
Will update when there is light [emoji4]
And then there was light. Going to do some more tweaking tonight. I think they look ok.
  • Like 5
Did you get the reflective or non-reflective? Looks good.
I got non-reflective flat black
22 hours ago, Deadpoollane said:
New truck
I got 33s and rancho quicklift put on yesterday
How much is a typical install cost for the kit and does it just level the front or raise back and front?
It was $200 for shocks and tires to be put on it lifted my front about 3 1/2-4 inches because my stock tires where only 31.50 tall
For the back it’s just the rancho 9000 xl so it doesn’t lift anymore then how much bigger the tires you get. Mine went up a 1 1/2
What size tires did you go with?
33/12.50r17 but I have read people fit a 34.** 12 inch wide.
But I’m guessing you would have to remove the air dam and zip tie your wheel liner back.
