1 minute ago, Enough said:
Will this take the place of a lighted Bowtie in your grill ??
Yeah I'm gonna add some LED's that flash with the beat of the music! ?
Maybe the flashing lights will keep the turkeys off of your hood !  ?
?? Havent seen them around since one made the mistake of going over the fence into my neighbors back yard where he keeps his 9 dogs! ?
Either that or the Butterball messed with their heads !
Forgot about that one!
Built yet another subwoofer enclosure for my 2016 Regular Cab from a combination of 13mm and 18mm Baltic Birch plywood to scale from an actual Bowtie emblem
Nice clean work man! Where abouts is that gonna fit?
Sent from my LG-G710 using Tapatalk
Thanks and it fits behind the passenger seat of my Regular cab. I had to relocate the jack tools and will use that stud as well as make a bracket from the jack mounting stud to secure it in place
Edited by Marv88
spelling
25 minutes ago, Marv88 said:
Thanks and it fits behind the passenger seat of my Regular cab. I had to relocate the Jack tools and will use that stud as well as make a bracket from the Jack mounting to ecure it in place
Looks awesome, would be cool to have in your bed if you did a bed cover with a pass through the bed and cab walls.
Thanks! I built one for my El Camino years ago and the guy I sold it to had me make him a pedestal  so he could mount it in the back of his old school Blazer.
Edited by Marv88
spelling
No pictures of anything cuz phone died after I was done. But got around to installing Speed Engineering long tube headers and Y pipe. Also did the Lingenfelter 160* thermostat and trans thermostat mod. Oh and changed the spark plugs while the headers was being changed out.
Too funny, I have a guy who wants one built with the sub in the middle, coaxial speakers  on either side and an amp recessed in the back so he can put it in his bed for tailgating!
Think you could come up with a Bluetooth system for what he is looking to do?
Between the two of you, you might be onto something.
I was thinking the same thing and the amp we will use actually has bluetooth capability to play music so no headunit needed!
 Come up with a waterproof case, and you might be able to apply for a patent, until GM sees the Bowtie.
Maybe you could trade the rights for a new truck.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
