24 minutes ago, STRMTRPR said:
I hardwire everything.. but ya you can run el lighting from a battery pack with a some AA batteries to create "wearables"
If you think the ambient lighting may be too distracting check out Google and have a look at the OEM lighting options in the new Camaro's and Mercedes-Benz E class cars.. it's not for everyone but the Automobile industry acknowledges the custom car crowd
Where did you hard wire it to? (depending on how, does it turn on and off with ignition..etc.)
there's a few places you could wire it to...  over head lights, ignition, maybe even for when the headlights turn on.
with overhead lights just look in the footwell lighting thread for the wire
for ignition, i take power from here: ignition power   (check the 3rd and 4th pics in the post)
not sure where the headlight power wire is, but i'm sure it wouldn't be too hard to figure out
Stopped by to take some spy shots of the truck while the fenders and bedsides get some paint [emoji102]
Can't wait to see this done. Do you have a build thread?
I do not, I considered making one but wasn’t sure how popular it would be. You can follow me on Instagram if you have one. Or I can make a build thread now I suppose lol
On 8/28/2018 at 8:52 PM, STRMTRPR said:
Started laying out my el wiring today.. need some help with the tie breaker vote.. red or blue?
large.20180828_172011.jpg.75a42bf5aad5ea77c2394a3144c7ee97.jpglarge.20180828_172049.jpg.b165d9fc623e57cfcf544f95e5a52234.jpglarge.20180828_201820.jpg.c19344f8c4b891d6ebc308e5d1a574f1.jpglarge.20180828_201744.jpg.758539ad74a37a642e38926bb92e580b.jpg
The el wire is temporarily setup.. the finished setup will end at the armrest like the daytime photos and not extend down along the switch panel. The problem I have is red or blue.. daytime the red pops more on the door panel but night time the blue matches the oem dash light
I would go with blue
make a build thread!!!   :)
i'm always in the build thread section checking out current and old threads - i LOVE seeing what other guys have done to their trucks.
i've gotten lots of ideas from them which has lead me to do a bunch of mods myself
make a build thread!!!   [emoji4]
Lol okay y’all have talked me into it. I’ll get everything typed up tonight after work
Looks good Expensive.  Digging that mod.
I just finished wiping down my interior with Distilled Water and a light mix of Woolite.  Took the dog to vet and he slobbered door panels, seats, and console.  Luckily my X-Act liners protect the carpeting.
1 hour ago, Trucks-R-expensive said:
Finally finished my side project! LolLove the look of the LEDs. Can change to any color!
How'd you do it?
Definitely Blue.
If you just tie into the small LED behind the door handle you may be able to get them to dim with all the other interior lights using the factory switch.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
