Installed a Tyger rolling tonneau cover and, in doing so, discovered I had OEM bed lights.  Next project, removing the lights and installing LED strips in the bed.
Are you interested in selling the bed lights?
3 hours ago, bc-chris said:
he already did...   :)
Much appreciated! I've been away more than not lately :sigh:
.. painted my calipers red to keep them from rusting... well I got 3 out of 4 done before it got dark.. progress is slow when it's the long weekend and the cherry moonshine ? is cold! :Plarge.20180901_195838.jpg.2b54541ac5580ddca73441e38be62cdc.jpglarge.20180901_195848.jpg.3167dfaea4141db58ee9282ab7ddb435.jpg
*Edit* Did some searching online but was unable to confirm what the torque spec for the bolts should be (do not have manual yet). I need both the front and rear for the caliper and spindle mounting bolts. Any help is much appreciated
*Edit v2* This seems to be the most popular search result online and are the values that I am going with..
Front caliper to bracket bolt - 74 ft.lbs.
Front caliper bracket to knuckle bolt - 170 ft.lbs.
Rear caliper to bracket bolt - 38 ft.lbs.
Rear caliper bracket to axle bolt - 148 ft.lbs.
Edited by STRMTRPR
Not my truck, but had someone drive up to me today for some install work.
2015 Sierra
Dash Swap (Leather Dash swapped in)
DL8 - DL3 Mirrors
Center Console Upgrade
Denali Leather Door Panels
Ran out of time for after pics, but here are some of the work in progress.
  • Like 6
Looks like a lot of work lol
It was. lol. 7 hr install.
What light strips are you going to use? can you link?
also is there a thread for this type conversion?
It would have took me at least 20 hours!
Once I remove them, yes, I would be open to that.  I was actually going to research here or reach out to @pgamboa to see if there is a female plug like that in the lights that I can get to make the install as clean as possible.  To be clear, I'm just removing the light 'pods' and wiring in string LED's using the OEM harness, I'm not removing the harness.
Edited by Darmichar
I haven't looked yet.  You can get rolls of string LED's with adhesive backing on Amazon for like $13 a roll.  I used 4 rolls of them before to put under the rail of a deck on my old house.  Those weren't bright enough for what I want to do here so I'd have to research it.
I would be curled up on the floor of the garage in the fetal position.  That looks like quite the daunting task.
Installed mpg caliper covers 2016 silveradoab4b29726166d3828c405fe8ce6dbd70.jpg074f96f155ba32f33fdc9e73ad3624a2.jpg
Had these on my 2016 with Factory 22s... the fronts were making contact with the wheels and took them all off. Wasn’t happy about that!
I’ve done it 3 Times now. It’s not bad. Just a lot of 7mm bolts. I like to remove the wheel, turn signal lever and shifter. Makes it easier to remove the dash. Someone removing the entire steering wheel column is easier... maybe one day, I’ll try that on my truck.
Even swapped his glove box lock cylinder over for the OCD win ;)
Happy customer :)
  • Like 3
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
