MTM Foam Canon is the only way to go. (I tried a few cheaper versions trying to sh save money, didn't work) I use a special conditioner for my ceramic coating, in between washes I use Jax Wax as well, they have a special soap for foam cannons, both are well worth it. I have never timed it, but I can wash half of my truck at a time with no issues.
Funny thing is, my brother sells both...
I quickly whipped up a bike rack for our upcoming trip.  I painted the 2x4 black after I had it sized up.  It keeps the bike steady and upright, and does not take up too much bed space, as you can still slide totes and other gear under the front of the bikes.
I'll have to tweak it a bit when I get a roll up cover for the bed later this fall.
29655352497_fc8b03e0f9_c.jpgUntitled by Ryan Jakob, on Flickr
  • Like 3
I got the cheap foam cannons on amazon... kinda regret it... They do the trick but not what i'd like to see. I plan on getting the MTM soon.
What conditioner do you use?
What jax wax product?
7 hours ago, jgraves13 said:
The foam will run off about 3-4 min in (most of it). The spray nozzle is adjusted all the way to the minus side (less water, more foamy) and opened a little bit.
Using CG honeydew, with a dusichin foam cannon (supposedly the same as the CG foam cannon).
Washer is a sunjoe electric 2100psi 1.76gpm. it could be a dilution issue as well, I'm doing 5oz of soap to 25oz of warm water in the cannon.
I wouldn't think the finish is too slick. But I guess anything is possible!
I had the same issue you got...
I picked up a dewalt 3400psi 2.5 gpm pressure washer and the amount of foam is ridiculous.
I'll take a picture of both later today, if I can crutch my way out to the garage, I'm still in a leg splint, and on crutches. I did get the arm splint off though!
I forgot to mention the pressure washer, you really do need the pressure/power to complete the whole idea. The key seems to be no less than 3,500 psi., that is just from what I found.
Yea there is no way around it... on the electric ones you just can't get the pressure up enough.
Rube Goldberg would be proud Ryan! :D
Great Idea on hauling bikes.
I made a pvc bike rack that fits under the tonneau cover. 3765b857ec4cebe01cdb54c0c1f827e3.jpg
Sent from my Pixel 2 XL using Tapatalk
1 hour ago, pronstar said:
Ratchet straps seem sooooo much easier...?
If just carrying my one mountain bike, I don't even use ratchet straps.  I just lay it in the truck bed.
When I carry two bikes though, my bed is usually full of camping gear too, so it is helpful to reclaim some space under the bikes, as well as keep them to one side of the bed, close to each other.  Fruthermore, it is harder to find a place to put a foot down in the bed, and sometimes the cargo obstructs the tie down points as well.
There are 50 ways to carry bikes in a truck, each with pros and cons for each scenario.
Edited by rkj__
I know the feeling, been hobbling around on crutches since 1 July.  Hopefully, I’ll get some “good news” on Friday, my next (3rd) follow-up appointment.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
