21 hours ago, diegosaurus said:
Color matched side mirrors and door handles. Added oem offroad sidesteps.  Trying to decide if I want to plastidip window trim and remove side panel trim.  Before/after pics:
How did you color match it!?
I need to do this to my truck.
Also, use autodip... way better stuff.
57 minutes ago, Crazyjoker77 said:
Free mod with some leftover LEDs and a spare controller I had laying around.  Was a real pain running the wires under the carpet without removing the seats...  Controller is capable of dimming them so they aren't as obnoxious as in the pics and has a RF wireless remote.  Out of convenience I just tapped RPO power from the driver side fuse panel panel so they come on whenever the key is in and stays on until its removed and a door is opened.
What controller did you use?
What is RPO? Can you show where you tapped in?
I purchased them off ebay.  Thanks for the advice.
Do you have the part #'s? I can't find my color when i search for them.
no I don't have part #'s.  Searching for them can be tedious.  Try searching by paint code also.
  • Sad 1
On 9/15/2018 at 11:34 PM, Ravenkeeper said:
What did I do today/tonight?
PICKED UP MY NEW 2018 SILVERADO MIDNIGHT EDITION!!!!
Pictures to come tomorrow.
My daughter took this one, with my iPhone, while we were out for frozen yogurt, in Lancaster (CA).
  • Like 3
Congratulations Chris, that's a great looking truck! Have you recovered well from the ankle injury?
Foot injuries, and doctor told me Friday that I can start “limited” walking on it, around the house.  X-rays show that the 2-4 meditarsals are healed, but there is still some pain in my foot as I put weight on it.  4 more weeks until my next follow-up, and until I may return to work.
Ugh, sorry to hear you're still having issues....you and your family have been through a lot with this ordeal.
aliexpress link
RPO is retained power.  On when they key in in the acc or on position and stays on for 5min after the key is removed or untill a door is opened.  Already tapped into it for my dash cam install so just spliced in the led controller.
Blue spade terminal going to the inline fuse is the tap.(beside the square 50A purple fuse)  RGB controller is just held in place with some industrial velcro.  Can also see the nut/stud I used to ground just to the left of the white connector.
For those who are debadging their trucks, and have removed the gold bowtie from the tail gate, would you contact me by pm? I want one of them for my new truck. Thanks!
13 hours ago, NoLand said:
Installed my new Grillcraft grille, getting rid of some of the chrome.
Look's Good - is that a overlay ?? Thanks
Dropped off my 15 for the power steering recall and driver seat side to side movement tsb.
I have some led lights coming to do ambient lighting inside, grill lights and rear marker lights under the tailgate.  I’ll also do the air box cutout mod to go with my airaid cai tube. New Wix air filter (throwing away the k&n the previous owner out in as it keeps getting my maf dirty and causing hesitation upon acceleration) and a new cabin air filter.
Edited by squeak93
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
