Thank you both. Do you know the capacity with this cover? Stock is 5.5 pints/2.75 quarts if I’m reading it right. So what is the new quantity with this cover? I ordered it so I need to go ahead and get me some AMSOIL fluid too. So these folks don’t make a front cover? If they do I didn’t see it. You running 75W-90?
The new capacity is 3.xx quarts so you need to order 4 to make sure you have enough.
No there isnt a front one that I know of.
And yes on the amsoil 75w-90.
Sent from my SM-G955U using Tapatalk
I am waiting on the next video  about the one that they are making i thought they were very helpful vids I was thinking about buying one until I saw them and how it works
Saw the same one, he’s now coming out with his own model which looks just like the the G2 and all the others. He got a lot of attention from these videos and got exactly what he wanted by doing so, “attention!”
Sent from above
Regarding all the diff covers convo. Banks power did a pretty interesting series of videos on how the flat backed covers mess with fluid dynamics and heat up the fluid, while overfilling or filling more than the 4qt set amount can cause excessive aeration in the fluid which weakens it's performance.
Seems like the most performant setup for longevity, regardless of towing or not, is to keep the stock cover.
That’s actually false, banks made videos that got that type of attention and obviously found that they do work cause “now” he’s made his own versions too. He made those videos for publicity reasons and obviously worked. He’s now introduced his own versions to add to the list. I’ve had mine changed twice so far along with buddies of mine and found absolutely zero excessive wear on any diff parts.
Sent from above
That’s correct, I believe there’s an additional additive added as well for limited slip diffs
Sent from above
Because of convenience of having mine done every 7k miles at a buddy’s shop, ( I know, overkill) Lucas 85w-140 plus and add a friction modifier Dana Spicer # 43161
When changing out the fluid Twice, and after 35 mile highway run I’ve had the off-road shop look at the fluid and found zero issues due to my OCD on preventative maintenance
Sent from above
  • Haha 1
I ordered a yearly spring cabin air filter and some spraymax 2k clear in a can.  It's easier to just use that instead of breaking out the hvlp and making a paint booth.  I have to go to my local paint supplier and have a can of the black mixed up in an aerosol can, and then I can finally finish these headlights!
Thanks! I’m just gonna order 6 quarts and do both. May as well do the transfer case while I’m at it. I’m not going to add a friction modifier (unless I read compelling reasons) and couldn’t even find one on the AMSOIL website. I assume both front and back use the same 75w-90. Yes I do know the transfer case doesn’t use the 75w-90, my intentions are to do both diffs AND the xfer case too.
Edited by SS502
That's my plan too, get 6 qts of amsoil 75w-90 and then get 2 qts of their auto transmission fluid for the transfer case.
If you don’t have an AMSOIL account, you can go through @Black02Silverado and get a pretty good price. He hooked me up with my first order of engine oil. Better than I could get without a Preferred Customer Program. Not trying to sell anything, he even got my first year free.
They’ve already made one, findings were inconclusive which now (as was expected) Banks is coming out with his own version to add to the increasing amount of new Diff covers entered into the market. In his video he even stated that he doesn’t even know what the outcome will be on his new design. As thought, publicity stunt while working on a new diff to get a contract with GM on their new HD diff covers. It was a way to attract attention for his name, BS’er!
Sent from above
I don’t buy what he is saying one bit. While I will admit, I am adding the G2 98% for looks. The added capacity and cooling effects are a bonus. It may not be one bit of a benefiting Mod but there is no way I can believe it has any negativity other than making my wallet a tad thinner...but it’s my wallet :thumbs:
You’re absolutely correct! His first video started off looking for reasons not to have an aftermarket Diff Cover, his last video has him introducing his Banks model. I found his first video to be BS especially after I later found out he’s one of the manufacturers out there that were trying to get a GM HD contract. It’s all publicity and even his video states he has no idea what his diff cover is going to produce, guess there’s a dumbass/guinea pig born everyday. These fin cast iron and aluminum cooling systems have been around for over 100 years. On board ships, the keel cooling systems even have fins on their outer radiator boxes. Everything Banks has done is for publicity and he’s got it, GM is now planning on using him for rear end mods.
Here’s an article on him winning the contract for the newest military vehicles and yes, these are the same vehicles that have been grounded due to massive breakdowns and major motor issues, yeah, all you have to do is some research.
https://official.bankspower.com/insider_news/banks-wins-massive-engine-contract/
Here’s a new article on the new military JLTV’s Banks has worked on.
https://taskandpurpose.com/army-jltv-maintenance-reliability-problems
Sent from above
Made a box for the under the back seat btw I can’t wrap a Xmas gift so I think it turned out good 57c08e0317586bd31bd1f40814c28e4b.jpg03517da852a2167858b5b7135f2a22c4.jpg43e486bfde28eb24db4e1e959f22faec.jpgbd0ff9875213a1d80d318b92a62ab6ab.jpg
  • Like 4
    MASONV88888888
    MASONV88888888
  • Who's Online   0 Members, 0 Anonymous, 1,661 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
