I don't see how it's "false". He goes over why the current aftermarket covers aren't good, shows the fluid dynamics of them, shows aeration, talks about how some of them aren't getting oil to the front pinion. When he has shown the lower half of his cover it's clearly different from the others on the market. BD has the most similar except it achieves the additional oil level with an added cavity on the bottom which is clearly going to cause issue with the fluid dynamics.
Now I don't know if his diff cover will be available for the smaller axels in our 1500s but it seems incorrect to say his info is wrong simply because he is planning to make his own. Additionally, having yourself and a buddy without issues doesn't speak much to long term wear or performance.
To be clear, I don't think a diff cover is going to make or break anything in the short term, but in the longer term it may be responsible for additional wear and tear.
I do understand your concerns but as a business man I also see his introduction into the Diff Cover market as well. These aftermarket Diff Covers have been around longer than you and I and constantly upgraded with additional cooling properties.
I’ve had aftermarket Diff Covers on many vehicles with zero failures (wish I could say the same for other stock parts) and same for my friends. The G2 is another example of an excellent design and ease of maintenance which helps make changing your Diff Fluids much easier and sooner leading to a well maintained rear.
He said his findings are based on square aftermarket Diff Covers which last time I checked my Diff Cover wasn’t but again that being said he purposely mislead everyone questioning Diff Covers and then later decided to come out with his own version which he’s never done before. He also went on to say that his findings are inconclusive and that he has no idea how well his Diff Cover will work but I’m sure no different than the rest. I noticed his design had large fins from the inside too which IMO looks flawed and possibly his attempt keeping fluid from breaking down but no way capable fitting. Moving on, he starts with questioning the validity of Aftermarket Diff Covers and whether they work or not, moved on to now getting into the business of making his own into the already well established and flooded Diff Cover market. Banks has been replaced by so many newer and MUCH BETTER designed products out there and this is just his way of a comeback, the more I think of how he started out with questioning the validity of aftermarket Diff Covers in general and then making his own version speaks mounds, got your attention and others as well, I’ve got to much experience in life and especially life’s manipulations feeding only fears.
Again, I’ve been running aftermarket Diff Covers for many years along with buddies of mine and not once having any issues. He’s a BULLSHITTER!
Sent from above
Real simple solution to me.
Pre- purchase a weld in drain plug.
Remove stock cover for a service.
Have drain plug welded into the stock cover.
Re-install.
Anyone know where the OEM diff cover is made? China, Taiwan, etc.
Part # 25951487
Part # 25951487
Why?
Why?
[emoji4]
So there can be an end to the diff cover debate. If the OEM cover is made anywhere else then here's a good enough reason for me to replace it! [emoji631][emoji631][emoji631]3d4cdb7fe0b9e016d279cb1a8f15f294.jpg
Sent from my SM-G955U using Tapatalk
  • Like 3
Re-install.
[emoji4]
That will 100% void your warranty altering factory oem parts but will not void your warranty using an aftermarket Diff Cover.
Sent from above
You’ll see a change coming especially with HDs in the near future.
Sent from above
On 3/16/2019 at 6:04 PM, SS502 said:
So Skip Lock is AMSOIL’s brand and you’re saying it’s no required? Oh and heck yes on the recommendation! I’m totally happy with what you did for me. :thumbs:
I was away from my computer and I don't play well replying with my phone. LOL
You don't need any extra modifier for you truck.  You will be good to go.  :)
  • Thanks 1
Finally got to use my front mount hitch today
64885035-ADCF-478-B-B7-C9-28-E20-F5-DC72
Edited by Jacoby
  • Like 4
That’s pretty bada$$ right there!
Finally got the tail gate light strip installed. Gonna get under and hard wire it when I get more time. Right now it’s just plugged into the 4-pin trailer harness and hardwired to the driver side reverse light. Here’s a few snaps during the day. Looks pretty bright so far. We will see how long it lasts, being a Chinese knockoff. 0f17f4b63478cc8401af0135e5ed6ff5.jpgc4bc45d9249c5a22dc4758d196dcf34d.jpg
Sent via my cellular device utilizing a chat forum thingy!
  • Like 4
No pics just gave it a bath. Wanting to lift and get summer wheels and tires on and also install subs from my 14. Everything is on hold for the moment wife said she wanted a divorce so don’t know what or when plans will happen O’well.
  • Confused 1
  • Sad 2
Wow!
Sent from above
Sounds like plans will be on hold for a while..... then you will be in charge of your own time, good luck.
Sent from my Moto Z2 Play using Tapatalk
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
