On 3/11/2019 at 2:44 PM, Shakeydeal said:
The tail lights are Spyders and I got them from Real Truck. The third brake light is from Pro Tuning Labs.
So far I like them. The reason I bought that third brake light is because it's almost an identical match to the "C" bars in the Spyders and other lights like that.
Shakey
How are your lights holding up ?
spyder tails and the third brake light ?
i bought the spyder tails but I need the matching third brake light now
5 minutes ago, Shakeydeal said:
So far so good. I guess time will tell.
Good to hear.
They have the third brake light for 58.99
going to order it
thanks
Emptied my RXP dual catch can...this is at 650 miles. I’ve posted the 100, 400 and now 650 miles. This is a total, I have been keeping a running total.
On 3/6/2019 at 4:22 PM, SS502 said:
First pic 100 miles, second 400 miles. These things work!
On 3/8/2019 at 11:03 AM, SS502 said:
Been asked why not just use a water bottle. Answer is; I relocated my can(s) to the fender directly over the spare battery tray. I can not fit a water bottle under the can(s) so I was going to just use a aluminum pie pan. I found this in the same isle at Walmart and grabbed it. It fits perfectly in the battery tray, directly under the can(s). So I just lay this in there, open both drain valves, go have a coke or whatever and let it drain unattended. After about 10 minutes, I just close both valves, slide this out and I'm done. No mess, no babysitting the empting process. I put the lid on it to keep the results from spilling while waiting on disposal. Eventually I will empty this into my used oil container and take it to the recycle place up the road to dispose of it.
The picture is for size reference, not sure the actual measurements.
The red wire across the back is the power source for my AMP/Subs. No aux battery.
Just to show results from all three empties and the size of the Pyrex.
Friend of mine powder coated my tow hooks red. I think it turned out nice.483e93d071b02534880e0c4ad0f8cf60.jpg
Sent from my SM-G975U using Tapatalk
I did the same with a friend for $25. Looks good and we saved $$$! What lift setup you have. Clean looking truck dude. 0c528cb61a18360bff49f92c6556a70e.jpg
Thanks. Readylift 7 inch. Just finished the install a couple of days ago.
DQS tow mirrors installed today. Custom modified with boost auto switchbacks and puddle light from A1 auto mirrors! BIG SHOUT OUT to PhilG for the most professional install I’ve ever seen. Looks factory. Couldn’t be happier
020a57ed4b1f0b7f571fef1e1658c3a8.jpg1272dde3f985f86f1273f2e07cc60182.jpgd0fa316a601960e121897cdc60b2ff06.jpge9d10db2f4ff7458799fe065f9a3f27a.jpg
  • Like 9
Took my grill off and interior trim panels in preparation of installing my echomaster front camera tomorrow.
Took apart my spare tailgate handle and started sanding for some fresh paint. Going to get some paint tomorrow.
Had “off-road” lighting button/switch installed today to control aftermarket light bar from diode dynamics. Again shout out to PhilG for the custom install and great work!
  • Like 3
I’m in love with your front end. I think the subtle “Chevrolet” and chrome accented grill really sets it off. Is that how Z71s come?
That is one awesome looking truck.  Well done.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
