Just order some new strut mounts since the driver side has given out!!! (Strut is still good, the mount that broke is circled in red) This has made my truck squeaky af been a week finally got her in the shop to see what was going on hopefully get it fixed this weekend part should be here Friday . THANKS ROCKAUTO ????
Edited by Frankielozano214
On 7/13/2020 at 8:41 PM, Granite7 said:
Added Bilstein 6112s in the front.
79d3beb11511cc90b0d602c526c390d1.plist
This color looks beautiful. Is it just the way black is showing in the picture or is it something else?
Thanks, that color is 121V Tungsten Metallic. On GMC I think it is called Iridium Metallic.
It is a metallic charcoal grey that really reacts well in various lighting. Sometimes it looks more grey. Sometimes you get a hint of purple in the metallic.
It is a bear to keep clean.
What is the paint code on it?
Officially started de-mod on my 14, I have been on the fence about getting a 19 for a while, an opportunity came up, and now I need to use my 14 for work......
welp the stain that was removed before i bought the truck on the headliner is back.
3rd brake light had water in it so im assuming its that.
ran a bead of silicone around the gasket area and screw holes. fingers crossed!
I put a aftermarket light on mine and just used some stick on foam padding and it worked perfect
Installed an LED light strip underneath my tailgate.
I'd rather have a Putco but for $60, I figured RC was worth a try. Has 3rd brake, full brake, turn signal, and white reverse light functions.
Sent from my SM-N975U using Tapatalk
  • Like 3
i ordered the thicker gasket but was too impatient to wait for it lol
I’ll be interested to see how that works for you. I had one but it had some circuitry issues.  when you had the taillights on while hitting the brakes and turn signal, it would flash the whole bar instead of just one side. Hoping they got that worked out.  Was a good bar otherwise
Dropped my new wheels and tires off at a shop to get mounted and balanced. Picking them up on monday and throwing them on the truck after work. Feels like christmas in july!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
