I love the look of these. But they also look like a shin laceration for us graceful peeps. [emoji37][emoji37][emoji37][emoji37]
is that 3rd one handy back by the bed? I’ve always liked the idea of that.
2 minutes ago, slide187 said:
I love the look of these. But they also look like a shin laceration for us graceful peeps. emoji37.pngemoji37.pngemoji37.pngemoji37.png
is that 3rd one handy back by the bed? If always liked the idea of that.
yes I wanted to be able to reach in the bed from the side, I am kind of tall so I put these on mostly for the wife and kids, little easier getting in but getting out I have to get used to just sliding out, too short for me for a step-out
Finally got around to adding footwell lighting. I used these little LED license plate lights from Amazon and after trying numerous locations under the dash/kick panels etc I found they actually worked great under the seats (I’m going to add a couple more facing rearward in my regular cab).
FA1E4CA1-B89C-42DC-8B10-D67C782B9DC1.jpeg.58a7b5a63cb55a8ad814317cdcf892ff.jpegE4475092-B806-4C4C-B603-38DB21A1C94C.jpeg.7f87f1981607a82c68811a432bd994ce.jpeg69486349-4B23-4426-8FFE-2B699626F580.jpeg.a1b7fece4c18e46c546d9a75f378f306.jpeg
drove it up in the mountains to about 7000' feet to harvest a Christmas tree
  • Like 5
Replaced the battery. Went with a Duracell since they seem to have good reviews. They’re made by East Penn Battery which also makes Deka. Truck’s been cranking slower lately and this morning, it barely started. Original battery was dated 4/2015 so I guess it was due. My ‘08 Silverado spoiled me because it still had the original battery when I traded it off in 2016.
Welp, biggest service yet for the truck today since I've owned it; 95,000+ miles. Gonna bite the bullet and get it all fixed! Started out with just the water pump/belt a couple weeks ago, now I just discovered that I have the infamous radiator crack and the cooler lines are leaking. Unfortunately, I don't think the TSB is going to cover this now (being 2020) but gonna bring it up just in case.
Also going to be getting a tune up/having the spark plugs and wires changed. I'm hoping that after all this work is over and done with the truck will run like new again. ?
Little lighting upgrade. A lot easier to see when b/u  with 20% tint on side windows. Also illuminates b/u camera much better
Did you add lights to the steps ??  Look's good
Just installed some led strips with my amp steps turned out good!2F94DED6-5BEF-469C-9DBB-3F1FFC5CBAE5.thumb.jpeg.29e9bff45bacbc93ec9bc36dfa3c0775.jpeg
Oh my[emoji50]
I dig it Frankie
Sent from my Pixel 3 using Tapatalk
  • Thanks 1
2 minutes ago, dieselfan1 said:
What are the lights ?
Some eBay led strips that are ip67 I think,
here’s couple shots I just took
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
