5 hours ago, doubeleive said:
another question comes to mind, did you cut the oem trim panel to keep the ac controls or is that a kit of some kind that let you keep the oem ac controls?
I used a panel to keep everything clean. Metra 99-3014G
Finally got some time to throw these on!!!!!
ITS HAPPENING!!!
Sent from my SM-G986U1 using Tapatalk
13” stock vs 16.1” “BBK rotor”
DONE!
Those wheels are 20s right? If not what size? I remember reading that you need at least a 20 for corvette brakes
Yup!! Minimum 20”. These are 20x9-18 or -12. Plenty of room.
Nice! Could you possibly quote part numbers for everything you had to buy for this? I'd like to source all these things before I get new wheels, but unfortunately that probably won't be for a while... [emoji28] looks fantastic gotta get a wide shot in the sun tomorrow for sure [emoji106] great job man!
Thank you! Everything is on this page https://ctsvbrakeswap.com/collections/gm-truck-suv-kits/products/gm-truck-suv-6-piston-c6-zr1-caliper-big-brake-bracket-kit
21 hours ago, SWOYER said:
Diode Dynamics SS3 pro Foglights
Pioneer DMH-WT8600NEX 10" head unit with full JL / Focal system
Beam pattern and brightness blows the morimoto's out of the water, really fills in the ditch blind spots left by the projector retrofit. Easy install under ~30min. My only gripe is that they stick out of the bumper by about an inch, it used to REALLY bother me but now it doesn't really bother me much. I assume this is either lazy engineering or intentional to keep the heatsink fed with airflow.
HID's only
HID's + Fogs
Fogs mounted
Pioneer head unit
Wow, I knew the SS3 pro were bright and better than the Morimoto XB fogs, but I didn't think by this much!! Got any pictures of just the fogs on by themselves? Just saw they came out with the SS3 Max, wonder how these compare.. Couldn't imagine spending over 500 for fog lights tho ?
amber light has slightly more lumen's in general and the cutoff is higher, of course more watts makes a difference also
and the reflector beam pattern makes a difference spot/wide, etc
Edited by doubeleive
I'll see if I can snap something. But in reference to to the XB's, the beam pattern and amount of light on those was just not what I was expecting out of a fog light. I think the SS3 is the better choice regardless of color, with the amber probably being a little more useful. I like that they basically pickup where my HID's let off, so seeing deer approaching from a field etc has been greatly approved. On a side note, haven't done enough testing to see if the beam pattern is obnoxious to other drivers yet... no one flashed me when I left them on but i'm sure they're blinding so I don't usually run them unless on dark roads.
Ok quick question. I made some polished aluminum plates I thought about putting on my front cross member of my lift but undecided what do you guys think yes or no?dd6375fae9cb549f91bf574a92163e5c.jpg
Sent from my SM-G988U using Tapatalk
Love these racks. I put one on my last truck (Tundra) and it fit perfect. Need it mostly to protect the rear window from my ATV. Super high quality. And I loved how the working harness plugs right into the trailer connector but behind the bumper. Nice and clean. They’re strong AF too, and they look great. I put a whole 12x12 deck worth of trex over it from the tailgate hangin over the cab and it held that no problem.
I am actually quite impressed at the rack itself. While on deployment I was considering building it myself out of steel but rescinded to just order it while I was about to get home. And no regrets on my choice to order it after installing it
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
