4 minutes ago, Dinner said:
What was else was needed to make this work aside from the new cluster and wheel? I'd like to do this to my WT
Hi @Dinner Please check out this video on YouTube from dopezamora. You will need to order the Denali cluster programmed from White Auto and Media. The new steering wheel with controls. Snagged mine new off Ebay and a LIN Bus harness that I purchased from @pgamboa harnessdr.com. This harness will give you control to the cluster from the steering wheel and also restore backlight illumination to the steering wheel buttons. I hope this info helps.
I had tow mirror cameras installed on each rear view mirror and a front camera installed, as well as a bed camera.
The infotainment screen can display the two rear view tow mirror cameras and the bed  camera at the same time or separately.
The front cam has its own selection in the cam menu on the infotainment screen.
The coolest thing is turn signal activation.
On right turn signal, the right tow mirror cam comes on - same for left turn signal, left tow mirror cam comes on.
Cancels when the turn signal cancels and goes back to whatever the infotainment screen was doing at the time.
Awesome mod! (or upgrade, as the case may be)
  • Like 5
  • Thanks 1
What is this modification you speak off? Is this a kit? Can these cameras be mounted on regular mirrors or do they have to be the tow type?
Installed new tires and rims, and blacked out all my emblems, and most of my chrome pieces.  Also, completed the OEM off-road light kit, with the OEM light switch.
  • Like 6
@Raven Z71
The cameras I have require tow mirrors.
They replace the bottom portion of the tow mirror with the cam housing and necessary wiring.
Not sure if there is a version for regular mirrors.
Fortunately, after install, the @pgamboa turn signal harness for the tow mirrors wasn't affected.
Edited by MikeBMW
8 minutes ago, MikeBMW said:
@Raven Z71
I have what sounds to be the same system, it's called Intella Haul. I also have the White Automotive option added to the rear camera so I can see what's behind me while driving. When I ordered my '17, I had the dealership install the system. They will need to program the truck anyways. Great system, now they are making the trucks work a similar system right at GM...
Yes, seems the same, or similar, except my backup cam only comes on in reverse.
If I didn't have the bed cam, I could hook up a wireless trailer cam - there are only four cam hook-ups on the cam module to the infotainment screen.
And, as you mentioned, dealer installed as programming is required.
First one my dealership has done as my truck stayed there 2 and a half days while they figured it out. :D
Edited by MikeBMW
@Raven Z71
Fortunately, after install, the [mention=159655]pgamboa[/mention] turn signal harness for the tow mirrors wasn't affected.
I installed an EchoMaster Intellihaul system for a local customer. Left/Right camera. They were lower caps for the tow mirrors. Wired high mount camera and a wireless camera. There was a module that was installed in between the radio module/screen. It was PnP. No dealer programming was required.
Same, Phil, EchoMaster on mine.
I thought there was programming required.
I was really happy to know it didn't effect your harness operation.
Thank you!
1 hour ago, MikeBMW said:
@Raven Z71
I remember seeing the Intellihaul system, but I lost interest since I wanted to retain my original mirrors as I do not have a need for tow mirrors.
I can understand but I really wanted the tow mirrors since I haul a trailer from time to time.
The cam system makes it even better.
To be fair, between the tow mirror install, entire door harness replacement, and the IntelliHaul system, (front cam, bed cam and tow mirror cams) I was in for about $4000 (including the bed cam)
Edited by MikeBMW
Yep. The cameras for this system is a direct connection from the module to the lower mirror caps. So it wouldn’t have :)
When I bought mine it was only 1k for the system. Bed cam, both side mirror cams, wireless cam for my race trailer. I had to buy the tire mirrors separately. Now they have cams for the stock mirrors, but they stick out from the side, not underneath.
As far as programming, that is what the dealer said they had to do because the signal was not correct. Were they lying, who knows. Truck had zero miles, the camera system was also new on the market at the time...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
