I ordered one and plan to stick the old one in the tool box. For $30, it’s pretty damn convenient until it’s not and you can easily throw the old one back on.
Yeah i would def save the stock one. I guess my concerns are more about being out somewhere like on an ATV trip and all the oil leaks out while you’re out riding for hrs cuz the valve failed or something and you’re a few miles away from anything. And god forbid you don’t notice and start the truck. Idk. Maybe I’m overthinking it. Hahhaa. But I do that with stuff like this.
Just curious how durable they are.
Improbably, both of my windshield wipers failed yesterday at the same time in the exact same way - and it hasn't even been below freezing for more than a week. Oh well, these were on the truck when I got it about a year ago so I had no idea how good they were anyway. Upgraded to Bosch Icon based on the recommendation from The Wirecutter; they've never steered me wrong in the past. I used to do the Rain-X Latitudes, so it'll be interesting to see how these compare.
I have always been a die hard Bosch fan for wipers. Maybe it's just my bad luck, but never had good results with longevity of Rain X. I think the Bosch Envision series were introduced 2 or so years ago, and they are by far the best set I've ever owned. Going on a year and a few months on the same set that have seen lots of rain, snow, and everything in between. Still function like they did on day 1, and no streaking!
Put on new wheels today, went from silver to black.
35x12.5x18 BFGs. 18"x8.8" Chevy stock black aluminum.
IMG_0145.thumb.jpg.c40aaad0f6a6e560ad2eae6a08cb1a23.jpgIMG_0143.thumb.jpg.c34daa7d279275bd957de508c299787c.jpgIMG_0144.thumb.jpg.6a2ff59f4a08a4261a9f5d63e5ffd755.jpg
  • Like 3
Get you a rubber vacuum cap or something similar to cover the end of the Fumoto valve and nothing will drain out if the valve gets hit. You can also tighten it to where the handle is up out of the way so nothing can hit it.
I've got a section of tygon tubing I slip over the end of the valve and drop into my drain pan when I pull into the garage when it's time to change oil. Open the valve and walk in the house. Come back out the next morning and I know I have drained the oil while it was hot, no splashes, no mess and easy as can be.
Edited by Eddie 70
Ok so these fumoto valves; I was toying with the idea of putting one on my ATV a couple yrs ago and I didn’t because someone mentioned the valve got all jacked up from trail riding. And wouldn’t open and then wouldn’t close, And I started thinking would I also NOT want one on my truck etc for the same reason? And thinking about salt and ice/snow in the northeast? Will these things hold up to that and not leak for years??? Looking for real opinions cuz I know alotta you guys have em and I don’t think I’ve ever polled a forum about it, and I have no personal experience.
I’ve ran Stahlbus drain valve on my track bikes. Works great!!!! It’s a lot smaller than Fumoto valve and looks a lot cleaner. A lil expensive but definitely worth it.
Oh now THAT looks cool. Metal cap to protect the valve. And I take it when you push the other part with the hose into it that’s what opens the valve?
Thanks! I’m gonna look into these. I like that nothing is exposed when the cap is on. And that it’s metal.
Yup, push it and turn and that’ll start draining it. Very simple and the cap also serve as a second seal.
Wanna share what and how?
There off the T1's you gotta do a little trimming but took a minute with a Dremel.
Sent from my SM-G986U using Tapatalk
  • Like 3
Ground off the parting line and smoothed my lower control arms on the front side. I’ve been thinking about doing this since I removed the lower bumper plastic.
  • Like 4
Had a nice 60 degree day this weekend to detail inside and out. Not often we get above 30 in March! Bucket wash, clayed, Turtle Wax jet black spray wax and CG VRP on all plastic trim & tires. Wanted to see how the spray wax works compared to my normal sealant routine (chemical guys black light followed by butter wax). Just in time before we get snow and rain tonight.. 😕IMG_3949-R.thumb.JPG.0c92e904d2c0930df0ccdf091c0cff78.JPG
IMG_3951-R.thumb.JPG.132eb539d91ae79f68e02d86ee596fa6.JPGIMG_3968-R.thumb.JPG.21deb1de86637dd08de7b0d4bae2acd7.JPG
  • Like 9
I WISH!!!
We may have been lucky to break 50ºF today in the high desert in SoCal.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
