Installed Thinkware front and rear dashcams. Tuned it up with Diablo. Emailed back and forth with Lew to get what I need to do now so he can fix me up.
  • Like 3
Traveled out west to the in-laws and got some moto's in. Been noticing with even hauling a few hundred pounds on the interstate any slight hill incline will downshift. Going to look into re-gearing in the future since I haul a enclosed trailer often.
What did I do to my truck today?  I bought it.  I was a member here about 4 years ago but I sold my 2015 and somehow ended up getting a Tacoma.  Well, today I traded that in today because I've really missed my Silverado since I got rid of it.  Anyway, here is my new (to me) 2017 LT Z71 in Pepperdust metallic.  Already pulled off the dealer stickers and plate frames.  Also I still had my Weathertech mats and under seat storage from my 201520210322_162633.thumb.jpg.bfcea59c8506bf461e377eac69720383.jpg in the garage and put those in.  My mind is racing with all the things I want to do. Haha
  • Like 9
Nice I never see that color much around my area,
What's your budget? I like spending other people's money.
Sent from my Pixel 3 using Tapatalk
  • Haha 1
I'm with ya there - I've sunk over 8 grand into my 2017 since I bought it.
I'm really good at spending my money, time to spend someone else's! :D
$2500 here $2500 there .....whose counting[emoji857]
  • Haha 1
Really!! :crackup:Then how about you sponsor Pepper. I'll spend yo money. 😉
  • Haha 2
I'm really good at spending my money, time to spend someone else's! [emoji3]
Anything interesting?
Ah, let's see ... from my recollection:
2" front level, removed for a 3" front level and new UCAs. 33x12.5 tires replaced with 35x12.5 after the 1.5" body lift.
Rear spring lift and a i" rear block lift.
A locking under-seat steel box.
A roll-up bed cover. Bed extender, as well.
Replacement black aluminum wheels.
Front and rear splash guards - color matched.
Front hood bug guard and in-channel wind deflectors for all four doors.
A bike rack for the hitch.
An Autel MaxiSys Elite for diagnosis and problem solving.
Tow mirror upgrade (with @pgamboa harness) with cameras on each mirror and a front cam and bed cam.
Full Chevy floor mats and Chevrolet labeled door sills.
Pretty sure I'm leaving something out.
Oh, Carhartt seat covers ... I'm sure I'll think of more soon. :D
Oh, yeah, changed the bow-ties to black and put on the lighted front bow-tie.
My Chevy parts guys know me by name - whenever I leave, they say "see ya next week"
Often, that is accurate.
Edited by MikeBMW
  • Like 4
Tow mirror upgrade (with@pgamboa harness) with cameras on each mirror and a front cam and bed cam.
Oh, Carhartt seat covers ... I'm sure I'll think of more soon. [emoji3]
Gotcha. I’m always looking for something else to spend money on. Butttt I really need to stop lol. My truck woulda been paid off by now if I didn’t go down this rabbit hole.... and it’s a 2018 truck... smh.
Sunday, I pulled off the running boards, fender liners, and rocker panel plugs. Then, I flushed out the rockers and fender wells and hand washed the truck for the first time since last fall. I’m gonna repaint the board brackets and put them back on.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
