9 minutes ago, 14 Silvy said:
Looks good man. How you liking the Reklez arms? I'm torn between those and the McGaughys. Bad thing about McGaughys is being on back order.
Sent from my SM-G988U using Tapatalk
I like them but I should of sent them to get powder coated, not liking the cheap paint they used.
Silvy
I went with Kryptonite.
Lifetime warranty. $500
20,000 miles on my lift and these have been flawless. Grease every oil change.
Those reklez are pretty trick though [emoji15]090fe07726323aab7cf9ec9a2d50ece2.jpg
Sent from my Pixel 3 using Tapatalk
  • Like 3
Silvy
I saw those as well will look into them.
On another note I’m loving the new headlight harness I got from @pgamboa I can have parking light and fogs on like the rest of y’all ?
this is a 2014 Silverado LT with the 2016+ LTZ frontend but with the painted bumper
Edited by Frankielozano214
  • Like 7
Well honey hush don't that look purty[emoji24]
  • Haha 1
Not sure how to post videos?  Do I need to upload them to YouTube?  Tried to upload one in the post but the video dose t work
Yeah that’s the way I usually do it. Then post the link here.
The cold/snow have kept things a little slow, but I recently decided to change my cabin air filter. Had the new one sitting around the house for a while. I did the cardboard method and slid it under the old one as I took it out, and I'm very glad I did. To be honest, I'm almost positive this is the original filter and it has never been changed before (I got the truck used, not sure if previous owner knew about it). Noticed an immediate difference in the HVAC system! :)
Also cleaned up some small headliner stains and spruced up the engine bay.
Rain is giving us a break so I finally got a chance to wash and shine. Also, I like to take a run up the highway to blow most of the water off before drying and for some reason decided to try the trailer mode. I tried it once when I first bought the truck and noticed it shifted firmer at higher rpm but this was the first time under hard acceleration and it was like I unleashed  “performance mode” as this thing lit up that on ramp like greased lightning! (I got such a jolt I went down and up several ramps just to do it a few more times! ?)
  • Like 4
Dropped it off yesterday @ the local service place. 150k service; brake pads & rotors (originals still on it); anything left over from the 100k service that didn't get done; a front & back groan when I go over speed bumps; & a slight, intermittent noise from the right rear at low speeds (yeah, good luck with that).
Few Projects completed this weekend. #3 on the list was that i finally got around to putting in the external lighted bed light switch and an additional set of GM bed lights. This is a must have,.. No more going in to the truck to turn bed lighting on..
  • Like 3
Little update on the ceramic coated long tube headers. Just parked after about a 30 mins drive. Ambient temp is 46 degrees. The header at the top is 182F. The beginning of the Y pipe (coated with VHT primer and fire proof spray paint) is 257F. Not bad! Can’t wait to see what the temp differences would be on a hot day after some hard pull.
Also got the waste gate (my version of exhaust cutout) opening at 8PSI. Did a little quick pull. Its a lot raspier than I expected. The boost did dropped a little bit from what I can tell on the gauge, about 0.5-1psi.
Love this. Do you have a How To on this mod?
I used the mod here from jaeisber as a guide. The second set of lights was a kit i picked up cheap from ebay for a $100.
I wired and installed the switch first with the same color coded wire instead of using all black, an ran it down to the bottom of the truck first in the wire loom.
I just wired in the second set of lights to the original set under the bed rail.
Be careful. The light wiring (gauge) is super thin.
I also found the 12v hot out of my hitch connection was the large black wire in my harness..
  https://www.gm-trucks.com/forums/profile/203295-jaeisber/
Edited by 15bronzeduramax
Just wrapped these up as well...
Amazon.com: Prewired Surface Mount LEDs (5050, Neutral White LED) - 3 Pack: Automotive
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
