24 minutes ago, Alan Bowman said:
Can I see a pic?
I wanted to do an intake but I want a box.
the box ones they sell have glass with a seal to the inside. I wouldn’t buy it. Honestly I want like the factory box with the tubing to the motor. But I’d want the filter system in the factory box.
is that what your describing?
yeah, for my truck it’s low speeds going up hills. High speeds to but I drive in town mainly lol.
today after changing all the fluids I rode 100 miles ish. I got myself speeding? Lol. But the fluid definitely made a change. But, I only kinda did it half ass cuz I didn’t change all the fluid? Dropping the pan doesn’t drain it all. I’d guess some would be stored in running lines and radiator.
this V8 stuff is heavy. Speaking of that I read there is 10-16 fuses controlling fuel consumption all around. When I first got my truck there was 2 quarts of gas in the oil. WHEN IN DOUBT CHANGE IT OUT.I was thinking maybe the injectors are sticking? No way it’s leaking through the motor itself. Only 50k miles. Shouldn’t be the pump. Than I seen all those fuses I was like damn. Inside both front doors is a panel and under the hood. I should go check and see if any are bad and what my oil reads. I’ve rode 2k on the oil since the change.
I try to drive the truck on the weekend or if the wife needs the car. Nissan Sentra highly recommend. 2019. Put in a 100$ chip hella gains. Mpg went from 32-36 to 40-45. I couldn’t believe it. But, also the car has less miles than the truck so. Lol.
In the summer I drive a Harley 883 if it doesn’t rain.
just got a new job, distance is double, in the summer when I can ride… I’ll feel like the kool-aid man.
OHHHH YEAHHHHHH!!!!!
Here's the part # for the seal, Part Number: 22844822. You can cut open the stock one you have but it just finishes better this way imo. All its doing is opening up the face of the air box against the fender.
The air box I opened up is on the truck right now and I didn't take any pictures. But when I figure out what I like best Ill be sure to post one.
I should mention that I have header's, so any changes I've made may or may not be more pronounced then if running the stock manifolds.
Had a few days off this week before I start my new job on Monday, so decided to tear back into the headlights. I can’t ever leave anything alone!!!
Removing the old permaseal was a complete b!tch. When I opened them up the first time to install the Klearz, I went the easy way out and just mashed the perma down in the channel and put butyl over top of it. About 4-5 hours to remove everything and multiple times in and out of the oven. On top of that, I put a bead of clear silicone around the edge after the new butyl dried so had to get that off too. Live and learn...
Took the chrome bezel out, used Easy Off heavy duty oven cleaner to strip the chrome. About 10 minutes in on the picture below. 30 min process and it results in gloss black.
Installation of Diode Dynamics switchback DRL boards was next. Pretty straight forward process. 5 min epoxy to secure the boards.
Reassembly of the lenses and bezels.
PG9 cable gland on the back of the housing so I could mount the LED switchback drivers on the outside of the headlight. Wired it all up and test ran before sealing everything back up. Everything is good to go so back in the oven and sealed up! 250F for 10 min to soften the Diode butyl.
And the final results. Super happy with how everything turned out!
  • Like 14
Damn that look 🔥
  • Thanks 1
That's hot hot hot
  • Thanks 1
15 hours ago, dieselfan1 said:
That's hot hot hot
Dude!!! That’s nice. I’m so going to do this! Lol.
Just started my new job but parts are piling up. Got a set of rims and tires with tpms, zone 1.5 body lift, waiting for the 3 in rear blocks, I do have the shocks. They sent me the wrong lift 😒
You need to do a build thread.
Keeps all your mods in one place.
https://www.gm-trucks.com/forums/forum/171-vehicle-builds/#
I should have did my vehicle build on this site instead of gmfullsize 😂 just to lazy to make a new thread of my truck. Thinking of adding another 8 pods of Q1 rgbw rocklights these have that flow series leds too! Still haven’t added the 2” leveling kit to it yet nor have I done the 1.5” rear shackle lift yet 👎🏽
Edited by Frankielozano214
  • Like 4
5 hours ago, Frankielozano214 said:
Now that's hawt.
Edited by dieselfan1
I feel like there should be a stripper in that picture.
  • Haha 4
According to Carvana my truck is worth a few thousand more today with 150K miles on it than it was when I bought it 6 years ago with a thousand miles on it.
I was looking at Chevy Express vans and was shocked to find 2015's with 200K miles on them selling for $20K++
Whow!! So I gave it a look and BOOM!!
Okay....World has officially gone round the bend.
  • Haha 2
  • Confused 1
So Pepper is.. gone?! Am I reading that right?
Is there a Gm Van forum? Lol
  • Haha 1
Same. My ‘18 all terrain in ‘21 with 46k miles is worth $10k more than when I bought her in ‘19 with 12k. Never seen anything like that. It’s crazy pants.
Nooooooooo Pepper is alive and well. Just window shopping
Wish I started this when my Sierra was completely stock to see the progression. The only problem is I tend to get too excited and forget to take pictures throughout the project, hence only posting a few above lol.
  • Like 3
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
