Yea I agree it's over stayed it's welcome, just haven't taken the time to take it off yet!
Today I installed Air Lift Loadlifter 5000 Ultimate air springs (although I haven't connected my air lines yet). I just taped up the fittings. I get my compressor and tank next week.
Sent from my Nexus 5X using Tapatalk
Where did you get the frame tubes from? The post above yours seems to have his inserted the opposite. Didn't these were available. Looks like they are on amazon.
Edited by pgamboa
eBay
http://m.ebay.com/itm/322214207376?_mwBanner=1
Yep, I pulled into a convenience store parking lot on the way home from the dealer to get a drink, and pulled off the plastic dealer emblem while I was there.
I told the dealer if he could get the sticker off he had a deal. The sticker came off before I left.
If you have done something to your 14 and would like to share,please post here. Please don't post the How to in this thread.
Have a little time to install the tail gate light bar, replaced the bed light bulbs with led and install footwell led light..
Bed light replaced with this: http://www.ebay.com/itm/111217352865?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1381wt_1181
They are super bright..
Tailgate led bar with reverse: http://www.ebay.com/itm/400624564281?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_2571wt_1155
Not too bad for the price.
footwell led,1 led per area : http://www.oznium.com/prewired-superflux
driverside:
Passenger:
Rear :
Enjoy!
I just ordered some of these for my next project. I see that you tapped into Pin #1 on the BCM #7 connector (Dome Light Control Circuit). Where did you tap into grounds for each LED?
I grounded mine on a good bolt by each led. Grounded the ones in the back to a center console bolt and the fronts were grounded up under the dash.
With the fogs and bulbs on.
75DAB8F2-D6DC-4219-A258-A0A995AA17A9_zps
493FCBFF-6D35-4E66-B2F3-1CAD3B6F7502_zps
It took about 45 mins to swap these out. In the rain too. Lol. It looks so damn good. Hopefully getting some more paint for the grille this week.
  • Like 4
Now you need to paint the grille surround.
Sent from my SM-G930V using Tapatalk
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
