2014 Silverado MyLink question
kurtg2020
When you make a call, and you end the call, does it go back to the screen you where at before the call was made? If someone calls me and I hang up, it goes back to say xm, if that is what I was on before the call. But if I make a call, it will not go back to the screen I was at before, stays on the phone screen even when using voice.
Hi kurtg2020,
Our Infotainment Customer Support Team is available seven days a week, between the hours of 8AM - 10PM EST to assist you with concerns you may have. Have a great day!
Thank you,
Andraya R.
GM Customer Care
