This started several GM updates ago. My Android phone says it is connected, but from the truck, it says it can't connect.  I have deleted the phone and resynced it, I have done a hard reset on the infotainment system (works for a couple of starts), I have tried BT and USB.
Edited by bbqjoe
Have you updated the phone version?   I had that issue when I first got truck and updating the phone fixed that.
Edited by Z45
I am on the latest and it keeps saying on my phone that it is connected, but from the truck when I try and connect it fails 80% of the time.
9 hours ago, tioran said:
have you tried connecting other phones?
I don't have another android to try that with.
What about family members/friends?
I'm thinking maybe it has to do something with your phone🤔
I'm having similar issues, though, mine is more like a 50% success rate. I've cleared cache, restarted both phone and infotainment system, and forgot and repaired phone. Mine does work with a cable, but frustratingly very hit or miss with Bluetooth. It's a 2025 and worked reliably until about six weeks ago. Suggestions greatly appreciated.
Edited by Jason23
Hey there, @bbqjoe. We understand your concern about being unable to connect your device to your Sierra. Since your concern started a few updates ago, we would like to learn more about your experience so we may explore the best path of assistance. At your earliest convenience, please visit: https: https://s.gmc.com/support-request and fill out the support request form with all pertinent details. This form helps us gather the right information and ensures your request is routed appropriately for further assistance.
Thank you for sharing your experience, @Jason23. Your concerns for your intermittent Bluetooth concerns do not go unheard. We share the same desire for you to be able to use the features you rely on in your Silverado to their full extent. We would like the opportunity to learn more so we may explore the best path of assistance moving forward. Please visit: https://s.chevy.com/support-request and fill out the support request form with all pertinent details. We will keep an eye out for your outreach.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
