4wd issues with 2002 Silverado 1500
This morning, I managed to slide into a ditch and worked my way out of the snow and ditch with 4H. For some reason, I could not get it to engage into 4L. After getting out, I disengaged back into 2wd and drove down the road. Once I got to 20 mph, you can start hearing gears churning louder and louder, and at about 40 mph, you can feel vibrations through the gas pedal. I could not get the truck to go past 50 mph.
In previous use, I saw this problem, but if I stopped, toggled between 4 and 2, then restarted the engine, the gear issue would go away. However, when I tried this down the road today, it would keep on churning. I rarely ever use 4wd unless there is a lot of snow on the ground.
Any ideas? My first thought was that every time i engage to 4H, it would keep the gears in place after disengaging back to 2, but I am not exactly sure.
I would scan the transfer case for codes, and see what pulls up. Maybe an actuator isn't disengaging properly. Or...maybe it's internal, which means a lot more money.
Yeah my first thought is the transfer case but i find it odd this issue goes away whenever I let the car sit for a while and restart the engine. When I left work today to go turn on the car and test drive it a little, the issue was gone. Someone mentioned to me the vacuum could be a possibility.
there is no vacuum on the 4wd system on your truck(not a car) lol
you need to see a tech and road test with him ,
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
