Adding Home Link?
  • Replies 107
Not on the lower trim models.
  • 1 year later...
Just poking at you in fun, but that is the prime reason I don't leave openers in my cars.
So where do you leave it and how do you open your garage when you want to pull in?
  • 1 month later...
Hi Gang,
For those who have the Homelink from factory in your Sierra/Silverado...... Not that you've ever had to open up the overhead console and look - but the actual Homelink module - is that something I can order separately without needing to order the entire overhead console?
I just bought a 2016 Canyon SLT which doesn't have Homelink. My husband has installed many Homelink setups in previous vehicles (including this writeup on a corvette: http://www.lieblweb.com/homelink.html)
We're looking at our options - while wanting to keep it clean and make it as factory looking at possible. I thought I'd ask about the fullsize modules and see if that's something I can order separately. We're still poking around to see how we want to do this .....
THANKS
  • 4 months later...
Hey ladies & gents,
Just to give a quick update on this, I know this is a bit late but for anyone else wanting to know this. You FIRST need to go to some place like www.gmpartsonline.net and drill down to you make/year/model and ensure there is a option for a replacement for the trim/harness/buttons/transmiiter for your vehicle, IF you DO see these options, you more than likely will be able to do this OEM style and not aftermarket (not guaranteed based on you situation). The transmitter for mine is as stated by another guy, that all is needs is power, it doesn't connect to anything else like the vehicle computer or anything, it is self contained. I decided to do the research on this after being told from the dealership, "You can't add this to your vehicle".. Upon researching this myself, I found I could buy a new harness (to have the OEM HomeLink plug on it), Trim plate (to be able to add the buttons), the buttons themselves and the transmitter. All in all I think I spent about 180.00 to keep it OEM. I WAS able to do it. I have a video that show tips and tricks on a 2014 silverado LT and changing the said above parts on the overhead console.. I made a youtube video on this make/model/color for my truck. I seriously hope is helps others wanting to do the same thing. I also upgraded my OEM 4.2" radio (i04) without OEM backup camera to a 8" (i05 - no nav) with OEM backup camera on the same truck. I'm getting together a small video on this as well and post it on my channel in youtube.
  • 1 month later...
saw that many people had done the add on from an ebay visor homelink so i decided to make a video to share on how i did mine. hope this will help someone out on their project. it was not very hard to do and only cost about $9 it works very well and you need almost no tools. you dont even have to cut any wires no no void of warranty.
DIY HomeLync Garage Door Opener 2015 GM Truck
thanks to everyone in this forum for the inspiration.
saw that many people had done the add on from an ebay visor homelink so i decided to make a video to share on how i did mine. hope this will help someone out on their project. it was not very hard to do and only cost about $9 it works very well and you need almost no tools. you dont even have to cut any wires no no void of warranty. DIY HomeLync Garage Door Opener 2015 GM Truck
Thanks for the inspiration of all the people in this forum
From what I read on here, the sunglasses holder is apparently too small for most sunglasses. That's where I tucked my remote.
my Oakleys barely fit.. ...i use to wear cables on them and hang them from the rear view in my old truck. .but in this one.. they hit the dash.... booo
  • 4 weeks later...
Hey ladies & gents,
Nice Video Tazzin!
Thank you for the detail, I'll be ordering these items also for my 2016.
For $180 I think it's worth it, if I was to have ordered the package that had this option it would have cost much more...then again I purchased my truck used.
Looking forward to doing this DIY project.
  • 4 months later...
New Info. Just bought a grey overhead console off EBay from priorityautomotive2015 with homelink. He says they are new but are missing the airbag light as you can see in the picture. I also had a $20 coupon from ebay which lowered the price at check out.to $145 shipped. Great communication with Ebayer if you have any questions. The auction says he has 5 more units. When I get the console I'll see if it is plug n play on my 2016 Silverado LT Crew Cab. I will post my findings
I have been using these for years.
Since I can't park my truck in my garage, I'm paranoid about someone having easy access to my garage. Granted, I keep my entry door locked all the time and I don't have anything valuable in the garage.
Is homelink connected to constant power and able to be used if someone breaks into the truck?
unfortunately I have windows in my garage so they could break into my garage just as easily if not easier than my truck
Once I connect my homelink I will let the window down and see if it will work by climbing through the window. I think if I open the door the alarm will go off but maybe not. Will try
Finally got the console with the homelink Installed it Everything has power all buttons work. But when I go to program it It won't learn the code. It flashes slowly and just keeps flashing slowly until it times out. Tried 3 different transmitters. Put a new battery in the one transmitter and still no program. Any thoughts?
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
