Adding Home Link?
Ok here goes.. Good news Just received my console from Ebay Salvage yard console. $75 shipped Installed Drove down the road to program the HL and BANG in 5 seconds was programmed. Drove back to my garage---pressed the button and the door opened. Pressed again it closed. Success The consoles from Priority...... are faulty. Time for my next upgrade..
Did you happen to get the part # and/or date of the transmitter?
  • Replies 107
Just sent my two consoles back to priorityautomotive. So, I'm looking forward to getting my money back so I can do this! I'm wiring in my DL3 mirrors and auto dimming rear view with them as well. Added leather, heated seats and a full center console too. Removed the chrome bumper and have a black painted one now and added the chrome bumper filler at the bottom with tow hooks. The truck looks so much better inside and out. I just can't stop coming up with things to do. My next things are heated steering wheel, add passenger power seat and LED tails.
That's awesome. My next upgrade is install electric cutout y to a loud muffler on one side and the stock muffler on the other side. This way I can control the volume of the exhaust. and have dual exhaust. Going to try to use the sunroof switch in the overhead console to open and close the valve.
The date was 2015 on the transmitter. I don't think that matters. Good luck
Sounds like my mods :).
Alright so just an update. Got a new transmitter. Switched up part numbers to a newer model transmitter (23341161). Plugged it in and everything programs just fine.
Just FYI. I did go through a couple of other bad transmitters from different vendors. So I think part # 22944268 has some bad transmitters floating around.
AAAAH The sweet smell of success!
  • 1 month later...
Not sure why there would be an issue. As long as you have power to the transmitter, it should be able to be programmed as it is a 'self contained' unit that doesn't require anything else to do with the vehicles computer system, ONLY the power plug is required. There is a setup that must be done, http://www.homelink.com/program/watchvideo Hope this helps.. I do remember having to reprogram it after I messed it up the first time.
Might be a little late but this is a link to setup based on your car ... http://www.homelink.com/program/process/1
  • 8 months later...
Has anyone had any luck with 22944268?  I bought a complete console off of eBay and I have having the same trouble mentioned here with 22944268.
Seller refunded my money from the console and told me to keep it, so I was looking to replace just the homelink module.  Looks like 22944268 is about $30 cheaper than the new part 23341161.
  • 5 months later...
For anyone interested doing this mod on a 2018 (or wanting the bigger sunglasses holder with Homelink), by deductive reasoning, I found the new part number to be 84083245.
  • 4 months later...
So just FYI for anyone interested in doing this.  PN: 84083245 is a direct replacement plug and play that took less than 5 minutes to complete the entire install.  I removed the stock overhead console and unplugged the main harness connector and plugged in the part number above and it worked.  I only had to switch out the passenger airbag light and put into the new part.  There was no additional harness to try and find a plug in for (this PN above included the harness for me along with the homelink).
I did NOT have the have any extra plugs to try and plug in or find a ground or power wire as some have mentioned previously as everything connected through the main harness.
Programming took 1 more minute and now having functional homelink, lights and passenger air bag light in less than 10 minutes.
I purchased on Ebay for less than $100.
This is on a 2014 LT without sliding rear window.  Ash grey in color.
I'm guessing you sent that guy on eBay a best offer to get it under $100? What did you offer him? I need one of these
yea, i got 10% off. went back and forth a couple of times. Motown-partsman
  • 3 months later...
Great thank you
  • 7 months later...
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
