2.5" RC Leveling Kit and 275/65R20 Goodyear Duratracs. The tires rubbed just slightly on the fender liner, a couple zip ties solved that. Thx Mr. Drag Sledder for the tips.
  • Like 8
2.25 Ready Lift with 295/55-20 Nitto Trail Grapplers
What is the wheel offset? Do the tires/wheels stick out at all? Any rub anywhere?
20x9 with +18mm offset - don't stick out and no rubbing
Now that looks right..nice truck.
I wanted to make sure everyone got my setup on here as well.
2 1/2 RC level kit w/ 2" spacer in the rear, 295/55/20 Toyo AT2 Xtreme w/ 14' All-Terrain stock rims on my Denali. The front's rub a little, looking at adding .25 inch spacers in the front. Has anyone done this, will it stop the rubbing? I sent an email to RC and they said that "should" work but obviously would like to talk to someone that has attempted it. The offset is supposedly a +34 for the stock AT's so that looks to be the problem not the tires. Do you need to put spacers on all 4 tires to make sure they ride the same for alighment/tire wear....etc?
  • Like 4
Looks GREAT!!!
Just thought I would contribute...6" Fabtech lift. Federal Couragia M/T 35x12.5 on 18" Black Rhino alloys :-)
  • Like 6
Noticing a couple of "performance check" marks here. What that the send-off of your factory rubber? I know that's how mine want to go out.
2.5" Level + 1.5" Body Lift
20x10 ET -24 Moto Metal MO970
33x12.50R20 Federal Couragia M/Ts
No Rubbing / No Trimming
Are these a - 24 offset and which lift kit did you go with. I also want 20x10's on either 295 or 305 but I ordered the 20x9 and 295's with a rough country 4 3/4 combo lift kit. Seems like a big difference between a +18 & - 24 offset. Haven't installed anything yet. Thanks for your reply!
Sent from my SCH-I545 using Tapatalk
Edited by GTALLDAY
Those wheels look good on your truck. This is the best set up you've had by far. Keep it up!
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
