Damn that looks good. Next set of tires I buy is 305s. I'm having regrets with my 295s. I just wish Toyo made this size in a M/T or R/T.
Luster, could you tell me exactly which Dueler A/T you have? Just want to make sure I get the ones you have.
Thanks
SEY CK156 22" GM wheels, 285-45-22 Bridgestone Dueler A/T, no lift, no level, no rub.
5" Rough Country Drop Bracket Lift
1.5" Zone Body Lift
22x12 -44 2 Pc Fuel Mavericks
35x12.50R22 Toyo MTs
Slight rub fender side at full lock both ways and more exaggerated when in reverse
[/url]
20150602_172604_RichtoneHDR_zpstfbt66lm.
Edited by baggedlvintegra
Thanks man. I'd have 305/55's if I did a 1.5 body lift, but I really like these. They rub a little at full lock and in reverse
17x9 +2 offset. 285/70/17. (32.7 OD)
Think I'll rub at stock height?
295 70 17 nitto trail grapplers. 17x8.5 American outlaw wheels +15 offset 2.5 rc level kit. No rub.77f832d8ef14abb28be4866b669fcaa1.jpg
  • Like 4
Thanks
Bridgestone Dueler A/T RH-S 285/45-22
I have RC 2.5 with 295 55 20 toyo at2 on 20x9 with +1 offset and no rubbing.
How are you liking that setup, especially noise-wise?
For me, the noise is a non factor. A little louder than stock, but nothing like a mud tire.
2.5 RC level with 285/65/18 Toyo Open Country AT2's.
43A99D38-C58B-4360-BA56-71B80C17C460_zps
1FABA1A3-E2FE-437C-BD4D-D5FF0366B69B_zps
095D0E21-AA33-4C15-BA62-EE92C74C3EF3_zps
Edited by Buellrider
2" Shackles lowered back end, KMC690 MC5 20" x 8.5 15mm with Nitto Grapplers G2.
file:///D:/IMPORTED%20PIC%20&%20VIDEO/2015-06-10/004.jpg
Stock 22 SEY Wheels on 285/45/22 Nitto Terra Grappler G2. Quiet A/T tire that weighs about 30 pounds less per tire than the Trail Grappler (which I wanted). Since my truck has a 3:08 rear differential figured I should stick with the Terra Grapplers so I won't rob to much power from the truck. Going with the Nitto also significantly reduced the vibrations I was feeling above 75 mph.
    BigJake
    BigJake
  • Who's Online   6 Members, 0 Anonymous, 464 Guests (See full list)
