Does anyone have size 305/55/20 on a stock AT wheel? If so, any rubbing?
Thinking of either Cooper ST maxx, Cooper Zeon LTZ, or Atturo Trail Blades
Thoughts?
Edited by 1badtie
What are you guys torquing your lug nuts too for aftermarket wheels? In the paperwork for the rockstars I have they recommend using your vehicle oem torque specs (140 lb ft), but then give a suggestion of roughly 100 lb ft based on lug nut size. I originally put them on with 100 lb ft, but it got me thinking.
Here's my old truck, 2014 with 2" skyjacker level, stock-size (265-65-18) Firestone Destination AT
Clearly needed more tire so I added some 285/65 BFG KO2's
just some sunny day pics on my Intros..
NICE AND CLEAN. LOVE THE WHEELS. WHAT ARE THEY?
Intro Wheels 818s.
Installed OPT7 LED high beams and LED backup lights and third brake light. Tail lights come in tomorrow, then I'll only be missing the fogs.
Think you meant to post to the "what have you done to your K2 today" thread [emoji28]
Well this is embarrassing... I knew having 14 forum tabs open wasn't a very good idea :lol:
I could imagine worse happening haha
But to draw the attention away from the mispost, I'll get us back on track
Got some pics from a coworker today since I'm out of town and my rims and tires arrived, 20x9 Fuel Lethals wrapped in 35x12.5x20 Mickey Thompson Deegan 38s
32B60B99-C6C2-4F3C-936C-C42311BA0829_zps
Edited by Mike1220
Think this might be my next tire, found 305/65/17 for 260 a tire :D wasn't planning on a 12.5" thick tire but oh well i like the tread pattern.
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 755 Guests (See full list)
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
