You need a reset tool which you have to use even after rotating the tires. I plan on buying one after the 24,000 mile maintenance warranty runs out. The tire place might have one but if not just go by a dealer and maybe they won't charge just for a TPMS reset. Only takes a couple minutes.
Thanks!
All you guys that switched from the factory P tires to taller/wider sizes and got stuck with LT tires, what's the ride like? I'm leaning towards sticking to a P tire but wouldn't mind switching to LT if the ride isn't too bad. My truck is my DD so I keep that kind of stuff in mind.
I didn't really get stuck with an LT tire I wanted it. I didn't notice much of a change in ride quality… I just prefer an LT over a P rated tire…
22" Replica Denali Wheels
305-40-22 Toyo Tires
do you have any rubbing? any offset/lift, etc??
I went for a clean look with these 22"s
what tires? and sizing?
I put about 10,000 miles on the stock SRA's before moving to my Duratracs. I ran the SRA around 36psi cold, I now run my DuraTrac's at 40psi cold (rated for 80psi) . I've found the ride to be slightly stiffer but actually prefer the ride with the stiffer side wall- it also makes mounting curbs in NYC far less nerveracking.
20 x 9 Fuel Maverick wheel +20mm offset
305/55/20 Nitto Terra Grappler G2
2 inch Rough Country Level
do u have any rubbing issues with just a 2" level?
It does rub the fender liners some . bottoms out a little when hitting bumps . im going to be raising it up a inch or so this weekend so it wont bottom out as bad and rub .
I went from the stock 275/55/20 SR-A tires to 35/13.5R20 Toyo RT and haven't noticed a difference. There's an in tial change in feel in your butt but after a couple hundred miles that goes away.
Stock!
Anything I've done to this truck is 100% reversible. When I sell it in two years it will be as stock as the day it left the dealer!
Edited by Dropsix
  • Like 3
Finally pulled the trigger on rims and tires. Fuel nutz D251 20x9 with +20 offset. Tires are nitto trail grappler 295/55. Truck has a 2" level haven't noticed any rubbing as of yet. I think there might be some minor rubbing at full lock on the sway bar. Also tye wrapped the fender liner back just to be on the safe side and give a little more clearance.
Edited by Cody16
  • Like 4
Beautiful truck sir. I've always loved those wheels. I doubt I'll ever get rid of the stockers on mine but if I do those would be the ones to replace them.
Man, that looks good! Like those wheels. You can post as many pics of that truck as you want. I won't complain.
    Aries68
    Aries68
  • Who's Online   6 Members, 0 Anonymous, 340 Guests (See full list)
