Thanks for supporting my truck payment, lol, I see what goes into those tires everyday.
20X12 Fuel Maverick D260, with 35" Nitto Terra Grappler G2
I've been trying to find pics of someone with Anthracite Fuel Mavericks D542. I've only found these two pics. The Silverado's wheels look like anthracite but I'm not 100% certain. Has anyone seen these specific wheels?
2015 Rally Edition stock for now.
I plan to do a 4" Lift, use 1" spacers to bring the stock wheels to the fender, and then run 33's, and finally add an Edlebrock Super Charger on it.
Changed it up a bit
17x8.5 Method Racing NVs
285/70/17 Goodyear Duratracs
Edited by langston1726
  • Like 6
Changed it up a bit
That looks great. I'm kicking myself for getting 18s instead of 17s. I dig the big tire look.
Ready lift 2.25 front leveling kit and 2" rear blocks. 305/55/r20 Toyo open country mt tires
Edited by Ghart42
Changed it up a bit
Looks great. 17's with rubber is a good look. :thumbs:
**double tap**
Edited by Texas Husker
For you guys that have changed out your rims, did you have any TPMS issues? this morning on the way to work my front passenger sensor just vanished. I got the 1 min warning flash then stayed solid. we did a one for one rim swap, so we didn't rotate or anything, I drove it 30 min yesterday with no issues and 30 min into my ride to work the signal stopped. without the tool there is nothing I can do right? any ideas?
62 pages later, and I am drawn to this set up.... .Just looks good to me.
I went for a clean look with these 22"s
Changed it up a bit
How do you like the ride with this setup? Is it noticeably softer? Does the steering feel less responsive with the larger sidewall tire?
Love the setup, I think the 17" wheels on 33" tires look perfect on these trucks
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 253 Guests (See full list)
