do u have any rubbing issues with just a 2" level?
I have not noticed any rubbing as of now, had the set up for two weeks and haven't had any rub on the liner and havent felt a rub on the sway bar or control arm.
Stock!
Anything I've done to this truck is 100% reversible. When I sell it in two years it will be as stock as the day it left the dealer!
Looks good, I was thinking of dipping my AT wheels before I put them back on for winter. Will def be doing it now
Has anyone seen the new fuel maverick anthracite wheels on any new gm's or chevy yet? If so where. Could be a game changer for the iridium metallic guys. Cant wait to see how they will look!
Correct
I'm probably going with a 265/70/18 in kO2, no lift. OEM wheels for now. Eventually NVs. Hoping no rub on OEM wheels.
I had them, but they didn't look that good with the color of my truck. I switched over to black Mavericks and the truck looks so much better.
The anthracite may look good on an iridium truck.
Thanks for the pictures, truck looks awesome. Ya not sure how those would look now. Look almost like a light grey and the iridium is defiantly darker. Cant go wrong with the black though!
18x9 Moto Metal 970 machined +18 offset
LT285/65/18 Toyo Open Country AT 2
2.5 TGC front level
22x8.5 fronts wrapped in 265/40/22 nitto 420s
22x10.5 rears wrapped in 305/40/22 nitto 420s
Intro 818s.
  • Like 4
33x12.50r18 Atturo MT and 18x9 w/ 0 offset
Could you post a picture down the side of the truck? I've been looking at the same size wheel with same offset.
Never mind I saw your pics in the leveling kit thread!
Edited by Blue90YJ
Not a problem at all, they fit really well with plenty of clearance.
20x9 Gear Alloy 726 +0
305/50/20 terra Graps
2" level
How is the ride with this set up? Did your mpg suffer any?
Im thinking very hard on Torque Thrust ST's with Nitto 285/50R20's. I'm into the street look and will be keeping the OEM's for winter duty...
I know you want those rims which do look nice, but I don't think they would look good on any truck unless it's lowered to some degree. Don't have to be slammed, just a little lower. Just my opinion though.
I was thinking the same thing, just didn't mention it. My plan was to lower it in the spring, raise in the fall when swapping back to OEM tires. I haven't checked into the feasibility of doing this though, any idea if it's too involved a deal to do yearly?
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 209 Guests (See full list)
