I was thinking the same thing, just didn't mention it. My plan was to lower it in the spring, raise in the fall when swapping back to OEM tires. I haven't checked into the feasibility of doing this though, any idea if it's too involved a deal to do yearly?
It will cost more but would make it a lot easier to change heights, maybe airbags all around? That way you can keep it low and when it snows just air it up some. I personally would rather spend extra money to do that instead of installing and uninstalling a lowering kit every year.
How is the ride with this set up? Did your mpg suffer any?
It wasn't bad actually. My ride really didn't change much but I had stock 20s before. I think the main difference was being able to feel all the contours of the road with the tires being so wide. I lost about 1-2 mpg city and 2-3 mpg hwy. Not terrible IMO.
This is my latest set up
Edited by langston1726
  • Like 3
I'm trying to get some tires mounted on some black rockstar II's and I can't find a shop that will. I get either we can't guarantee we won't scratch them or we don't mount tires we didn't sell. Who knew this would such an ordeal, I wouldn't have purchased them online if I knew it was going to be this difficult.
Try to find a custom type shop that does aftermarket things. There's 3 custom shops in my town alone that's not a huge town (but not a small dinky town either) so I'm sure there's one near you.
Oh and the ones that tell you that stuff you should ask them, what about the ones that have factory chrome rims. I think they just wanted to tell to indirectly that they won't mount tires that you didn't buy from them.
Edited by SouthernSilveradoGuy85
You could always reverse level the truck, instead of raising the front just dropping the rear by removing the rear block & throwing a lowering shackle back there to keep it lower and leveled. Still a good height for normal driving but looks lower than a stock truck.
Well, plans changed. Got a smoking deal on these GM 22" chromes on Bridgestone's.
I'm painting the barrels black right now and should have them installed tomorrow.
  • Like 3
Those rims look really good. What are they?
Method NVs 17x8.5 +0 on 285/70/17 Duratracs
Plus 0 is almost exactly the same as a 1" spacer. Damn, that looks great. I want to push my stock wheels out, but pretty sure I'd need a 1.5" spacer and that might be too much.
Thanks man. You're right they stick out about an inch. Just enough to sling stuff down the side of the truck.
2015 6.2 LTZ Z71 with black Method NV 18x9 +18 and Toyo 285/65/18 A/T II
**** that looks so good. 18" w/33"s > 20" w/33"s. Do you have any side profile pictures? I want to see the wheel face from an angle and how it lines up with the fenders. Great looking truck man.
Edited by WendysOrBust
It's basically flush with the fenders. That is just a quick phone pic, when the weather clears up I'll take some good ones.
After a lot of flip flopping and debate, here's my set up...
Day I picked it up for reference
Some prep
Some colour
Painted the barrels black
The final look
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
