Thanks everyone for your input. I currently have 3.43 gears in my truck and was looking to get 33 inch tires. Tops maybe 35 inch but I doubt it since I don't want to lift it that high. I will take this into consideration.
A lot of GM trucks have been coming with 3.42 gears for over 20 years. I have 3.42's and have 305/55/20 (33x12.2) the taller tires change the gearing to around 3.29, you would need to go back to a 3.56 to get it back to stock rpm, etc... Where most people notice the change is going to a 35" tall tire over stock which drops you even lower, this causes lower rpm at higher speeds, "bogging" the truck, causing it to downshift more than previous. I thing a 35" tire you would offset this with a 3.73 gear, to get back to "stock" 3.42 range performance. You also need to take into consideration more wind resistance, rolling resistance, heavier wheels/tires, so adding more gear, say 4.10 would help more.
I disagree. Just installed a 4 inch bds lift with 285/65/20 bfg KO2's. That's a 34.5x11.5 tire. I have 3.08 gears. Yes, the engine runs at slightly lower rpms at higher speeds, but the tranny doesnt shift any more than stock. The main difference is accelerating from zero. I'm getting 18 mpg highway now and was getting 21 mpg stock.post-156672-146032998585_thumb.jpg
Sent from my VS980 4G using Tapatalk
I disagree. Just installed a 4 inch bds lift with 285/65/20 bfg KO2's. That's a 34.5x11.5 tire. I have 3.08 gears. Yes, the engine runs at slightly lower rpms at higher speeds, but the tranny doesnt shift any more than stock. The main difference is accelerating from zero. I'm getting 18 mpg highway now and was getting 21 mpg stock. 0330161709-1.jpg
Hmmmm. I have a 4" lift with 305/55/20, and 3.42 gears, highway speeds here are around 80mph, my truck seems to kick down more going over bridges than it did before.
Nice ass truck, btw
Mine rub pretty bad at full lock on the inside rears. I took the lower valance off too. Fuel Beast 20x10 -18 offset. 305/55 Toyo Open Country AT Xtreme
So, what's the zip tie/washer/magical mod that everyone keeps talking about. Haven't seen a thread about it.[/quote
Does that offset make the tires stick out past the fenders? Here in PA we cant have the tread out past the fender and I dont want to buy flares, thanks
2014 Chevy Silverado regular cab long bed WT2 with a 2"level, 17" Pro Comp Xtreme wheels -6 offset with 285/70R17 Mickey Thompson Baja ATZ.
Edited by thechainsmoker
Looks great. I really like that a lot of guys are going 17s and big tires. 22s have no reason on a truck. A "real" truck that is. haha
Yes, they do stick out.
D78968DB-44C7-4BCF-8721-B2D487103D55_zps
2.5" RC Leveling Kit and 275/65R20 Goodyear Duratracs. The tires rubbed just slightly on the fender liner, a couple zip ties solved that. Thx Mr. Drag Sledder for the tips.
Did you remove stock rear blocks and add 2" blocks from RC? How often do you tow a trailer and if so, do you notice a difference in truck handling?
Here you go. Top is before tires, bottom is after.
Kerr very nice looking truck. What's the level on it in the front and did you replace the rear block? What's the difference in these tires vs 305 55 20? Thanks
Yes the stock rear blocks were removed and the 2" blocks from RC went in. I trailer all the time a duck boat and a Ranger fishing boat. My Ranger is a multispecies rig weighing around 5,000lbs and causes the rear to sag. It still tows fine, but you can tell you are riding high in the front. I put in Air Lift 5000 series air bags and run them at 20psi, levels everything out and tows great.
Thanks man.
Front 2.5" level and 2.5" block in the rear. 295's are just a tad narrower than the 305's. The difference is minimal and barely noticeable, but enough to prevent me from rubbing. I do still rub, but only at full lock in reverse. The 305's would've probably required trimming.
Thanks man.
The 295's filled the wheel wells in just right.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
    • Howdy! New to the forum of course! My name is Casey, just picked up a 2024 high country midnight edition. First “new” truck in 24 years for me. Driving a 1998 Z71 since 2002. Have been on the GMT400 forum with lots of good info and help there. Nervous about driving these newer trucks and all their electronics…. Did a lot of work on the Z71 myself over the years. New truck is definitely a nice upgrade after 24 years. Photo of the old and new, still keeping the Z71 - has 320,000 miles on her and still running well!
