That would be great!
I found these mud hog tires for around $800 for the set so pretty cheap for 275/65/20. Thunk those would be 34s. Would love to fit 35s tho!
Look at this on eBay http://www.ebay.com/itm/262217845925
34x11.5 (275/65-20) without rubbing with certain wheels offsets
When I put my stock 275/55/20 tires and the 275/65/20 tires in a tire calculator it says the width is the same at 10.8" and the diamater goes from 31.9 to 34.1. Where is the 34x11.5 coming from?
My mistake, you're right it's 10.8, the 11.5 is the 285/65-20 which 34.6 and does rub slightly unless you zip tie the fender liner back.
2017 CCSB LT
Bilstein 5100s at top setting
Fuel Maverick 20x9 +1
Toyo Open Country RT 33x12.5
No rubbing. I gained a full 2" from Bilstein's. It sits 1/4" higher in the rear.
Thanks for all the info.
  • Like 6
2017 CCSB LT
I like that color good looking truck
Has anybody bought a set of these oe 22s? And if anyone has would you mind posting a picture of them mounted on your truck.
Edited by '16_Silverado_dude
Those were bought a lot in 2013 and 2014 when the K2XX first came out. Find the wheel and tires thread and search for "replica". You'll find a lot of good posts. Haven't seen much of them lately.
I havent seen these exactly. I've seen lots of the Sierra All Terrain wheels but none like the picture above. The picture I just posted are really popular and can be found everywhere.
RC 2.5" Leveling Kit
285/65/20 Nitto Terra Grappler G2
Stock 20" All-Terrain Wheels
Front/Side View with 34.6" Tires
Front View with 34.6" Tires
Nice! Any rubbing?
Nice! Any rubbing?
At full lock the the tires touched the back of the liner, but a quick zip tie and it was all good! I've been driving with them for a little while not and zero rubbing after that.
What's the difference between the two? One looks gloss the other looks matte.
If you look closely you can tell there is a differnce the the spacing between each Y spoke. One wheel has what looks like a rectangle between each spoke and the other has a jellybean size gap. May be hard to notice at first glance but the difference is there.
Ah, I see it now. If you find pictures of either wheel it'll give you a good idea of what it looks like. I personally like the first picture you posted more.
