They sure look nice! However I've been wanting to go from 20" to 18" for ride quality on Michigan's terrible roads.
I can't find a wheel I'm in love with.. Don't want all black and being a silver ice color truck the chrome is a bit much. Looking for a black and machined finish that's bold.
Here are my pro comp series 48 that I just got on my silver ice about a week and and really like the look. They are almost identical to Fuel Mavericks. I've gotten over a dozen comments in the past week. Just an option I thought may fit your style8450f0b5c68b7531421447ace267c441.jpg79d959192b1058ab0846dba851e15110.jpg
I'm also silver ice and want machined.  Haven't bit the bullet yet and cant decide either.  Tires incoming so I have to decide soon.
Edited by Austin66
Okay guys.. I'm getting tired of the black wheels.  Thinking about going chrome 22x10's instead of staying with the 20's.  Anybody have any good or bad to say about 22" wheels and tires.  For reference, I'm looking at Hostile Alpha's with Nitto ridge grapplers.
Thanks in advvance
Stay away from logging roads
Just got my new setup installed
285/55/20 BFG k02 tires
20x9 18mm offset XD820 wheels
2” rough country leveling kit
  • Like 7
11 hours ago, js4506 said:
Those look great. Does the tire stick out past the fender with +18mm offset? Any pics down the side of the truck to show how far it sticks out?
With a 2” level and 285/55/20’s on stock wheels.... would that work?
Thanks in advvance
I loved my hostile hammered Wheels, but the “chrome” which was pvd peeled in a year. I was told all pvd wheels are now having issues, and they’re no longer offering them.
Teaser.... just brought it home. Gonna take better pics after the sun gets higher in the sky and I can pull the stockers out of the bed. Damn thing is squatting a full inch with them in there [emoji35]
Wow..not cool at all...
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 522 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
