Hello people,
I have the Kicker sub-only for sale for the '07-'13 1500, '07-'14 HD crew cabs. I bought this used, it works fine, but it doesn't fit my '15 HD, although GM & Kicker part #'s suggest that. Anyhow, I'm looking to get $400 shipped OBO, to lower 48. Please message me, or you can call 406-439-4276, I'm in Montana.
P.S. I'm buying the correct sub & I'll include the new, uninstalled harness with this used unit. Hit me up or call with any ?'s, thanks!...Bob
Do you realize that you're posting this in the 2014+ thread which would also be the wrong part for our trucks? You should post this in the forum for the older body style.
Not wrong part if you have a '14 Sierra or Silverado HD Crew
Read the title of the forum again...
  1. 2014 / 2015 / 2016 Chevrolet Silverado & GMC Sierra 1500
  2. 2014 / 2015 / 2016 Silverado & Sierra Accessories & Modifications
So I want the sub amp kit and reading online it says not compatible with Bose OR MYLINK systems. I have an LT with mylink and no Bose. Dealership I called said this was correct. So anyone here install the kicker sub and amp with the 8 inch mylink system and if so, does it work perfectly fine?
I just responded to an older post, didn't even realize the title of thread, nor did I think it'd be a big deal.
There is two kits available. One includes a sub and an external amp, this is the one you will need since you do not have Bose. The other is just a Sub with amp attached to it, which is compatible with Bose and the one i have installed on my Sierra with Bose
It's not a big deal. I was just trying to help you out. Not many people intentionally want to buy the wrong sub, so I was just saying that you'd probably have better luck in the other forum.
To directly answer your question is Yes. If you have an 8" mylink without bose this is the correct system for you.
I just ordered the complete system amp and sub for my 2014 Silverado crew cab LT. I have the 8 inch screen but I do not think I have Bose speakers? Definitely did not have a sub. Is there a way to tell if mine has the Bose system?
Anyway, I just tried to install this tonight. It got dark in about an hour so I did not get it completely done, but I hooked everything up real quick just to hear it and nothing is working???
I double checked the connections and the fuses and everything seems good. I am hoping this system does not only work with the smaller screen stereos?
Anyone know if this works with the 8 inch screen for sure?
Any ideas why it would not be working? I was thinking maybe it is not grounded good enough? I did put the grounds where the instructions said to.
Thanks for your help!
It'll have the Bose logo on the speaker grilles.
yes it definitely works with the 8 inch screen. If you had Bose you would have a sub and would say Bose on the grilles of the speaker. double check that all you connections are good, fuses are in holders at batteries ?, ground? Its plug and play so not much could be wrong.
  • 5 weeks later...
Ok....I need to upgrade my factory non bose system, with this Kicker Sub & Amp combo for the Crew Cab. I believe the correct part number I need is 19303117 for my Crew Cab.
Question I have is on the instructions, do they tell you how to get the deck face plate or surrounding trim off, as I am really not wanting to figure that out the hard way and breaking something or some tabs.
Another question, for those who paid to have it installed. How long did it take a Audio Shop or Dealer to install, and how much did they charge?
Thanks!
Thanks!
I don't think you'll have to pull the trim off around the the face plate.
I had the dealer install mine, filling the GM Accessories website for price installed. Dealership never did one before mine so it was a learning curve. It took them about 4 hours but I only had to pay for an hour.
Kicker emailed me install instructions. Doesn't look too bad, but you do have to take the trim off around the radio.
Sent from Tapatalk App - Samsung S6
Yes the radio comes out because you have to plug in a harness behind it. It's easy enough to do. The biggest pain is fishing the power wires through the firewall
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
