So is it ok to use a wire instead of a diode? I bought some diodes and they seem to be way to small, used a piece of wire and everything works. Just wondering if the wire is okay for the long run
Thanks
Thanks
Diodes only push power one way whereas a wire will push power both ways. You can add a wire to a diode but you shouldn't eliminate the diode all together.
Regarding the fogs on with the High beams, has anyone done this on the auto dimming headlights? Any reason this mod wouldn't work on those?
Thanks
Doesn't that just mean that the reverse lights will come on with the cargo lights AND the cargo lights will come on with the reverse lights? Is there an issue doing this?
its exactly that. no problem doing it unless you don't want it to function that way.
Yes, and it presents no issues. I've been running this way for 2 years. In fact, I've had multiple people stop me to ask how I got my cargo light to come on in reverse because the added light adds to visibility when backing up at night.
The only issue I have is that they don't stay on long enough. Great MOD.
Define "don't stay on long enough." Cargo light system is designed to turn off when you put the truck into gear, whether it be R or D. May even only operate in P. With the mode, the lights will only come on in R (with diode facing the right direction), or (if wire mode or diode in "backwards") as long as the truck is in P or N.
I was turkey hunting last week and working on my tailgate. Kept clicking my remote to keep the light on. Timed out too soon
So i finally remembered to look. yup, the light comes on. I also noticed it came on when i turned the truck off and removed the key.
That's in your truck's "Vehicle Settings," "Lighting," "Exit Lights." I found that out too, the other day, trying to get my puddle lights to work.
  • Thanks 1
  • 3 weeks later...
I did mine last night and wanted my cargo lights on with my reverse lights AND my reverse lights on with my cargo lights. This was so simple... I just used a red scotchlock connector, clicked it in, and had this mod done in seconds. (already had a good idea which wires were where because I was also doing the diode for the foglights on with highbeams mod)
  • 3 weeks later...
Just did this mod..... One of the easiest things you can do
Sent from my XT1585 using Tapatalk
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,211 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
